EZ-Locker/Lockright/Quic Loc ......Lessons
Discussion in 'The Garage' started by pauly383, Jun 16, 2004.
  1. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well I learned something today ( its long , but good note ):
    My locker was good for 3 months, an occasional bang, but allright. Pretty much suddenly around the week before Memorial day the trouble began. It started locking/unlocking really violently, very often. Without even going around corners, taking off from stoplights would do it. Marv looked at it with me, all seemed well. Put it back together , same thing all over again.
    Pull my locker out for inspection, thrust washers seem thin. Drivers side was even burnt in a few spots, and wavy. So I order some from Ratech, they sent spider thrust washers , the small ones ...UGH ! Call DTS , they send me the right ones , cheap. Dealership wanted to sell a set of many sizes for like 40 bucks, and I paid $4.22 for mine.
    Ok so its back together , with only new thrust washers.........and it WORKS !!!! Much better than it was after the first day I owned it.
    So to anyone putting a lunchbox locker in, REPLACE the thrust washers. That little bit of material is enough to let the springs push out enough to keep it locked . And also like Marv told me , always use a new Pinion Shaft . /forums/images/graemlins/waytogo.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hmm...I've never done either of those....but the one in my DD does act up once in a while.
    Maybe I'll take your advice. /forums/images/graemlins/thumb.gif
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It sounds strange, but I aint fooling, just took up enough slack so when the springs push out they aren't extended too far and loose, which I assume caused it not to stay locked /forums/images/graemlins/k5.gif
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Almost Every post I reply to on lunchbox lockers I recomend replacing the Thrust washers and pinion shaft when installing them. I dont think many take my advise and learn the hard way.
    Also you should check the clearances everytime you change the gear oil. A locker puts a lot of stress on the thrust washers and will wear them.
    PS dont buy a Detroit EZ locker =junk
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Too late, my Qenuine Gear Quic Loc is actually made by the same people who make the Detroit. Outside of needing new thrust washers , no other problems thus far. We'll see how it goes, I don't plan on changing axles anytime soon /forums/images/graemlins/k5.gif
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Most don't understand the precision tolenaces that go
    into a used high mileage diff(carrier/case). And overall
    tire diameter can cause alot of wear and tear.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I believe it. Guy at DTS said same thing ( and based on what the truck I pulled my 12 bolt looked like I believe him ) . That previous owner probably never watched tires , or pressures , or even had a spare on too often, just totally worked those spiders and side gears. It works better than it did when I first installed it, so maybe I will replace them once a year or so. /forums/images/graemlins/k5.gif
