EZ OUT removal
Discussion in 'The Garage' started by stockk5, Jul 11, 2006.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Well i bought a dana 60 and both studs that hold the leaf spring on are snaped off clean at the housing. I drilled one out and tried an ez out and it snapped clean... . Now i was gonna give it to a friend w/ a machine shop that has some good drills and such, but how hard is it to actually drill out an ez out? Anyone got some good ideas on how to take the studs out completely so i can replace them? Thanks Mike
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Very hard...your going to have better luck welding to it than drilling through it...
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    Yeah, unless you have some high dollar cobalt bits, you're not even going to scratch one of those things.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Good luck
  5. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Done it. Bought a Cobalt bit for like $30,but it worked.
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    given the size of the ez-out needed for a d60 stud, that would be 1 big/ EXPENSIVE bit SET (your not just going to drill 1 size hole, it has to be stepped) and cobalt is still going to have a hard time...
  7. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    sounds like a job for the blue tool.......:doah:
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Get a carbide burr tip for the dremel tool. I have went throught his and that is waht finally worked. That and a center punch with a good point and you can chip away at the EZ out. The carbid bit eats it pretty good, but it's still tedious work. Save up all your favorite cuss words for that day.:D
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I broke on ez-out clean off in my exhaust manifold so now I only have 2 bolts holding on the collector. The ticking kinda pisses me off! :crazy: :mad:
    I have a good set of titanium drill bits, will those work?
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
  11. goldwing2000
    goldwing2000 Guest
    Drill it and use a smaller, reverse-rotation ez-out. :waytogo: :D
  12. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    pencil grinder to remove it. they get stuck on jets all the time and our maching shop usually uses a pencil grinder with a small rotary file to get them out.
  13. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    BURN it out!..
    I use the oxyacetalyne torch to vaporize broken off taps and E-Z outs!!..they burn quickly and throw sparks like a sparkler,and they will be gone before the surrounding metal is hot enough to be damaged in most cases...I'd not be worried about harming the axle,its plenty thick there where the bolts go..
    I'd find someone who's good with a cutting torch,and have them blow it out of the hole...a machine shop might have a plasma torch that works even faster,but it'll cost you--but so will having someone try to mill it out with carbide tools,etc...:crazy:
  14. BadBob
    Aug 14, 2005
    158
    Lyndon, KS
    Yeah, but you'll be there all day at it, and they won't be worth a crap when you're done.
  15. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    A Carbide drill bit
    is what ya need
