F-250 shock tower install - tons of pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Nov 16, 2000.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    Just finished installing the ford shock towers on one side (I can only do so much) anyway they look like they will work great. I used two holes from the old bracket and drilled one extra one (1/2" grade 8) and then cut the extra tower off while it was on the frame and even cut an angle on the end so it wouldn't look like a hack job.
    http://www.coloradok5.com/ranchoshockreview
    5,000 Pounds of American Rolling Steel
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    [​IMG]Very slick! Easier than re-fabricating you existing mounts too no doubt! Are your brake lines going to be long enough now? How much travel was being limited by the old shocks?
    Rene
  3. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Very. Very cool. I have some F-350 front shock mounts laying around from my '99 Ford. Now that I have seen what you did I have some work to do. Anyway did you make the rear shock mount crossmember yourself or did you buy it somewhere? Thanks. JT
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Nicely done!!
    Here are my ????
    How did you figure out the total hight of the mount you needed? Distance from the bottom mount to the top mount??
    I asume thoes are 9012s?
    Next, now I know what to ask my wife for Xmas[​IMG]......
    Good job dude, I think I smell something........is it....yes a tech review write up on how to xn taller towers[​IMG]
    http://www.burt4x4.coloradok5.com
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Very nice Steve. I guess that's what I'll be doing also[​IMG]. One question to add to the many already. How much of the Ford shock tower did you have to cut off? Thanks
    Boss
    http://www.boss.coloradok5.com
  6. CK5
    May 19, 1999
    21,627
    704
    CO
    The brake lines will be a tad short, they are 6" longer than stock, I will be going to a Dana 60 and will need new ones anyway, so at that point I will get longer ones. I cut off 4" off the bottom of the towers. The rear shock setup I had a local shop do. As far as the height goes, I put them at 6 1/2" extended, almost dead center, I was going to go a little lower but my measurment was off a bit, at the angle they are at they should have plenty of travel.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
  8. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    very clean. how did you determine the 6.5"?
    Knife.
    knife.coloradok5.com
  9. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    The picture quality is awesome! You don't need to say a word and I could just look through the pictures and see exactly how to make and install raised shock towers. How much did those Furd towers cost? It looks like they are new from the Dealership.
    CB
  10. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Thanks man, how did you know that mod was slated for Turkey weekend? The pics help tremendously. One more question though. Did you relocate your bottom shock hangar so it doesn't hang below the axle? I plan on doing this, was wondering if you had any ideas. Thanks for the help
    Bryan
  11. CK5
    May 19, 1999
    21,627
    704
    CO
    Didn't touch the bottom shock mount at all, I haven't had a problem with hitting it YET.
  12. Grim-Reaper
    7,385
    Atlanta
    Sweet....I bite, whats the part numbers so I can order them. What lenght shock are you running and how tall and brand of lift so I can get an idea if I need to run a different length shock?
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  13. Burt4x4
    6,854
    Ya what Grim said????
    I too would like to pick up a pair of towers and shocks then set them on my "TO DO" shelf of things to put on my K5!!
    Thanks for the info StevO
  14. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    One question Steve. When your suspension travels up the bottom of the shock will come up and that will change the angle in relation to the top. When this happens will the shock body still clear the front side of that shock mount. It looks really close. I like how it looks and after I see you ramp it and that shock clears through the full range of motion I would consider changing my, but I will not tell anybody that I used parts off of one of those 4 letter word trucks.
  15. CK5
    May 19, 1999
    21,627
    704
    CO
    Grim, I am running a Rancho 4" lift with Hill 1" lift shackels for 5" of lift (I will be going to a Dana 60 which has a 1" higher spring pad then removing the Hills in favor of ORD shackles to keep the same ride height). The shocks are Rancho 9012 the longest ones they make. The part number for the shock towers is "E5TZ-18183-A".
    Butch, It is kind of hard to tell from the pics but the lower mount (the one on the axle) is farther out that the frame, so the angle should be fine, I am going to try and ramp it tomorrow or Monday and take pics of it extended and compressed.
  16. Grim-Reaper
    7,385
    Atlanta
    Thanks! I'll see about hitting the dealer this week. I'm only on 2.5 rancho springs but measuring it to the stock 79 it's a full 3.5 inches over stock.
    Grim-Reaper
