F*cking transmission gaskets
Discussion in 'The Garage' started by cegusman, Mar 12, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I picked up a sm465 trany from a junk yard. I replace all the gaskets, installed it, put gear oil in it, and now every /forums/images/graemlins/angryfire.giff*cking gasket is leaking /forums/images/graemlins/angryfire.gif. I have allready lost about 1 quart of gearoil over night. WTF should I have used rtv with the gaskets? If so sould I put it on both sides? /forums/images/graemlins/1zhelp.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Wow, that sucks! I'd be /forums/images/graemlins/angryfire.gif too!
    I guess my best suggestion is to get some gasket-tack. It is the spray-on(aerosol) sticky gasket sealer made by Permatex. There are other types but the Permatex stuff works quite well. You will new and\or oil free gaskets, spray the stuff on (kinda like spray painting them) let it get tacky and then install. Torque everything down and let it sit a while before putting oil back in the tranny. Good Luck! /forums/images/graemlins/thumb.gif
  3. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here is a link to the Permatex sealant....
    Permatex
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  5. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes, you could use RTV, but I don't think you need to. The High-Tack spray is very sticky and will adhere everything together. Yes, apply it to both sides. /forums/images/graemlins/thumb.gif
