F#$@%!* Ifs Trash
Discussion in 'The Garage' started by yellowK20, Apr 21, 2006.
  1. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    well I just got done rebuilding the front end in my 97 sub:mad: :mad: I'd like to meet the mouth breathing slobbering dip**** inbread that designed that crap and Kick him in the nuts:eek1: ....... Okay sorry it was just a royal pain in the A$$ you have to unbolt the steering box form the frame to remove the pitman arm:doah: and then on the idler arm I dropped 2 sockets inside the frame and had to pull the front bumper to get them out:mad: :mad: I'm now looking for a ford 60 to replace all that crap . RANT OVER. Does any one know what size the hub nut is on the frontend??? I've got new rotors also and need to install them
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    ifs is the bomb,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,oh wait i ment it is a bomb
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    matco sells a pitman arm puller that doesnt require pulling the steering box.
    got one in my toolbox :waytogo:
  4. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    That' suck's man I wish i'd of known that before What's The part# I need to do my 93 next weekend:crazy:
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Do you write for the scary steering pages or are you just a fan?
  6. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Scary Steering?
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    cant seem to find it in the online catalog. try to find it in my print catalog or off the part itself when i get home. check back about midnight or so.
  8. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    thank's i'd sure appreciate it
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if its a 1/2 ton sub, you shouldnt need to pull the hub nut. they should slide right over the hub.
  11. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
  12. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    It's a 3/4 ton should be the same though I'll try it I've never done rotors on an Ifs truck before i just assumed that the nut held on the rotor
  13. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    If it is the HD 3/4 ton it is not the same. The whole hub has to come off so you can press the studs out of the rotor. The axle nut, IIRC, is in the 36-38mm range. I have the socket but without getting it out don't recall the size. Then there are 4 bolts on the backside of the knuckle that have a 15mm head that have to be removed so the bearing/hub will come out. That is where it can get fun. I've had hubs rust in so hard that I hammered on the bolts to drive it out and had to replace all the bolts.
    As for the pitman arm, I've been pulling them for years w/o a puller or removing the gear box. But that puller sure would come in handy!
  14. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    I just read in my haynes manual that some of these are pressed on I'll find out this morning got to go to done and get some new allen wrenches
  15. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    That pitman arm puller isn't cheap, but it's well worth the $. If you don't appreciate it the first time you replace your pitman arm, you definitely will the next time, and the time after that, and so on.... Why design something like that?
  16. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    yeah the whole frontend on these trucks is garbage I will never buy another 88' or newer gm (except an 89-91 blazer/sub/v3500) Well I got the calipers off and it is the pressed rotor type so now I need to run to town to get the socket as soon as I can get the size:(
  17. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    ill post the size this afternoon for ya, I just did a rebuild on my 99 3/4 ton suburban,:eek1:
    I had just done a 1/2 ton sub and thought it was going to be a quick job....:haha:
    also, watch the abs sensor on the front, the brake easy, you use a alan wrench to remove it, just stick the alan through a slot verticly in the rotor, its a tiny alan with like a 1/4 in thread size
  18. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    38 mil is what im seeing
  19. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    36mmnapa part#7759022 just got back from town fixing to go pull this crap apart thanks for the heads up on the ABS sensor Any thing left of your red 75???
  20. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Damn it wasnt that big of a deal when I replaced the rotors on my 98 K3500 and I didnt even use a manual. I seem to be the only person in the world that loves GM IFS for daily driver duties. The only trouble I had when I replaced my rotors was getting the 4 15mm bolts off that hold the hub on. They are tighter than a nun's **** and I think they have some kind of thread locker on them. I broke 3 craftsman sockets (lets not go there though) before finally going to vatozone (only place that was still open) and buying a set of metric impact sockets. After that, I got it all done easy enough. I think I used a standard socket of some sort on the CV shaft nut, just cause thats all I had. My steering components probably need to be replaced but I'll get around to that when I can afford it.
