F%#king fenders
Discussion in '1936-Present Suburban' started by dbltapp, Feb 1, 2003.
  1. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    I made an attempt to trim the lower rear half of my qtr panles, just under that ugly moldeing. I was using a Dewalt cordless sawzall, with a 24tpi blade, and it just wasn't working. It took me 15min to go 1"! I need some advise as to what to use. I can't inspect my burb w/o fixing the rust, and the cheapest way is to cut it off. I also intend to trim my fenders for fitment issues. Thanx
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/1zhelp.gif
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    You want a very fine tooth good quality blade. Or maybe use
    a cutoff wheel or soemthing.
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I use a cut off wheel or a 4" anle grinder.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i used a 4" grinder with speedycut discs, and a sawsall. i have a thing on it in my webshots.
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I used a cut off wheel. First, I marked my upper point with a sharpie and measured my lower point forward from the fende/door seem. The I marked that as well with the shapie. Nest, I put a piece of electrical tape for a guide connecting the two previous marks. I then used the cutoff wheel & started to cut. I probably tok all of 1 hr to do everything and trim the stuff underneathe as well. Anyway, good luck no matter how you do it.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  6. dbltapp
    Apr 25, 2001
    133
    Thanx for the ideas! I am getting my shoulder hacked on today by the local Navy doctors, so if they don't screw anything up I should be working on the fenders again in about a month.
  7. chvyhs
    Feb 12, 2001
    1,469
    I had the Navy doctors cut into my shoulder 2 years ago. They didn't do to bad of a job. I think they use a sharpie and a cutt off wheel too. What brach of the service are you in?
  8. dbltapp
    Apr 25, 2001
    133
    I am in the Navy, for 12 more months, unless they can come up with what I want! /forums/images/graemlins/deal.gif /forums/images/graemlins/rolleyes.gif
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used a sawsall on mine and it worked well. Just use good metal blades. I changed them quite frequently.
  10. dbltapp
    Apr 25, 2001
    133
    I was using a cordless, and it had no balls! I think I will try a cut off wheel next.
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've used a cutoff wheel. It works fine but it just takes longer.
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Use the Milwaukee Bi-Metal blades...24tpi....
    It will cut like "Butter"!!!! /forums/images/graemlins/cool.gif
    W.W.Grainger sells them www.grainger.com
