F!@#$NG DEATH WOBBLE...I have tried ever fix from on this board.
Discussion in 'The Garage' started by fortcollinsram, Jul 26, 2004.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well I finally drove the my newly swapped in D60 with ORD x-over and TCI ez-ride spings and greasable bushings....It was all fine and dandy until I came crossed the rail road tracks and then all hell broke loose...I never realized how bad this death wobble crap is until now....
    So far I have these bases covered
    -Rebuilt kingpins wish a couple washers under each cap.
    -ALL new TRE's for the x-over
    -Rebuilt steering box
    -weld-in and bolt-in steering box braces
    -new wheel bearings
    -all tires balanced to within .5oz
    I put a steering stabilizer on and it helped a LITTLE but the problem was still there so I removed the stabilizer until I find a way to fix this correctly.
    What do you all feel should be my next step? I am already planning hydro-assist and have about 50% of the parts, but like I said, I want to fix the DW first.
    I think the next logical step for me is to get the toe set correctly on an alignment rack rather than with my jenky-ass measuring-tape-and-chalk method. Then from there I think I will look closely at all the components involved and make sure they are all tight and solid...
    What are your thoughs...I have been too damn busy to mess with this at all and it ALWAYS something when you do swaps like these...
    Chris
  2. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    how much lift is in your truck? /forums/images/graemlins/dunno.gif
    i put 8" of lift in my truck and the truck was all over the road especially when off road i but a pan hard bar in and it slowed it down tremendously maby that might be the problem /forums/images/graemlins/dunno.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Before you do anything else, try putting fender washer on top of the Kingpin springs. If this works, your Kingpin springs are worn out, and the washer gives you more pre-load on the bushing. Check the bushings while you are at it, check the bushings.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    His whole axle is brand new and he has the fender washers already installed.
    Chris, check the toe again, and look at the tires from the front of the truck. Do they lean in any? Run a plumb bob from the fender down past the tire and measure. It was a problem on AZ-K5's D60 after install. Also check your pinion angle.
    Harley
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    In my case,
    Try lowering your air pressure in the front tires slightly.
    Try torquing the hell out of the ubolts...
    Then try toe-ing it out just a little bit at a time. When i smashed my tierod in the rocks it got deathwobble a lot worse (too much toe in!)
    Then put on the hydro assist.... and it will be pretty much eliminated except for HUGE potholes or train tracks. /forums/images/graemlins/screwy.gif /forums/images/graemlins/rotfl.gif
    I don't know how you guys without hydro assist do it...
    My truck is undriveable with death wobble without the hydro ram hooked up.
  6. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Woops, read that one a little to fast.
  7. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i had the same DW.replaced all the front end parts,it was still there.i got it aligned and it went away.that would be my next step if i were you
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Go get someone to throw it up on the Alignment machine at a shop. I bet either your Caster and/or your toe-in is not set right causing the tires to "fight" each other.
  9. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    Hate to be a kill joy, have the balance on those tires checked again. My first DW exp was after i got new tires, i think a lead popped off cuz when i took it back to the shop, was way off. Just a thought before ya spend more $$.
  10. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I was having a nightmare with my DW and it turned out to be a warped rim. I made it my spare and now i can get all the way to 65 mph before my chunked TSL's go crazy.
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The D60 is really picky on pinion angle. I had to use shims to make up for my longer shackles to get it close enough. The design of the 60's steering axis is usually at fault. The 60 *leans* the tires over more when turning. This helps tremendously when off road or towing heavy loads (reason for the design) but it makes the slightest difference from stock a PITA. This *leaning* is multiplied when the castor/camber crap is off a little bit. Then the tires really fight each other. I have had a horrible time tuning my 60. I had to replace the rotors and pads to make the truck driveable (they were warped from a fall off of their rebuild stand). This is my DD so it needs to be fully usable. I would check the pinion angle, and have the rotors turned as a next step. Getting the toe set right is a big thing too (but that can be done with a tape measure and jack stands).
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    How many washers did you put in there? I run 4 per side and have no death wobble no matter what I hit. My tires aren't even balanced...
    Rene
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    time to source a stiffer spring
    or build a preloadable upper bearing
  14. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I pulled py steering apart last night and think I may be on to something...
    Does ORD's x-over steering use the same TRE at every location (the knuckles for the tie rod, the steering arm and the pitman arm)? I have 2 different types of TRE's. The differences are VERY small. They both have the 7/8"-18 shank in the respective left- and right-hand thread but the "spindle" part that goes int othe tapered holes in the knuckle, steering arm or pitman arm are slightly different on the 2 different ends.
    Should the TRE's for all the locations be the same (in terms of the "spindle" design and size, not the shank thread)
    Chris
  15. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    You tried everything except Hydro Assist!
  16. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    add a removable track bar....
    Marv
  17. zcarczar
    Feb 10, 2002
    2,495
    ALIGN IT! I talked at length with one of the front end guys at work and he says first check the ball joints/ king pins then check alignment. I bet, as AZ-K5 said, your caster angle is out of wack.
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    does it do it when the PS belt is removed?
  19. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    MJ may be on to something. It could be a worn out steering pump. I don't know the exact science behind it, but the pump acts like sort of a "stabilizer" for your steering box. So when there's an input or jerk from the tires, it's transmitted through the draglink through the pitman arm and back through the steering box. A worn out pump cam cause the inputs from the tires not to be "dampened" effectively. Anybody else have any more input on this?
    Will
  20. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    fixed it...
    The toe was in just a little too much...I am now wobble free. I even took out the washers from the kingpins! I have no washers and no steering stablizer so I guess I can consider it solved... /forums/images/graemlins/thumb.gif THanks for the input gang.... Now I can put my hydro-assist on and go beat the pee outta it :-D
    Chris
