F/S 2" Add-a-Leaf
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by travis, May 26, 2001.
  1. travis
    travis 1/2 ton status
    Nov 17, 2000
    173
    Panama City, FL
    2" Add-a-Leafs which mount to the the front springs. No need to remove the front springs, these just bolt in underneath them. You will need replace your center pins. Use these leafs along with 3" or 4" blocks in the rear for a slightly higher (and level) ride. Asking $40 plus shipping. My zip is 32403. I'm guessing the weight to be about 30 lbs. Check shipping prices at UPS or FedEx websites.
    I also have 4 Rancho shocks for a 4" lift. They look pretty bad but work well. No leaks. Not sure if they are 3000 or 5000 series. More to follow on these once I get them cleaned up a bit. I'll get the part numbers and post them later. I'm thinking about $50 for all four.
    Email me if interested in either. I can get pictures later this weekend.
    Travis
