f250 shock mount and a limiter strap?
Discussion in 'The Garage' started by moturbopar, Sep 10, 2005.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi all I have question for you all about my f250 shock mount swap. What I am thinking about doing is leaving the upper bolt hole in the shock mount (the one at 12"in the picture) and using this to mount a limiting strap. do you guys think this would be an ok position to do this, or do you see any other problems with mounting it here.
    http://coloradok5.com/ranchoshockreview/f250towers.jpg
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i wouldnt, it will probibly make contact with your shock body... just bolt the limit strap directly on your frame
  3. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I agree. There are lots of holes already in your frame. Odds are one is in the right spot. I used the existing bolt holding on the engine mount.
