F250 shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WARP1, Feb 6, 2004.
  1. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I need new shocks soon. I want to try the F250 shock tower mount mod. Do the shock towers just mount (bolt? or weld?) to the frame. Can I order them new or should I check auto recyclers.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're discontinued. Good luck. /forums/images/graemlins/thumb.gif
  3. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    No there not. I went and talked to my local ford dealership, and the parts guy said that just a rumor is all.
  4. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    They are not discontinued, I just talked to my dealership a week ago and they are still available.
    Try this link it is write up on the install Shock tower install /forums/images/graemlins/thumb.gif
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I bolted mine on just incase I ever want to move them /forums/images/graemlins/grin.gif
    Yea,they have been disscontinued for a couple years /forums/images/graemlins/rolleyes.gif,but they are not obsolete.They are available still at the dealer.
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sure the ones everyone normally uses may be discontinued, but i can buy ones from a 2003 style super duty all day at 18 bucks each and they fit the same shocks.. and even look to be a sturdier piece..
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Only potential problem is if you are running a manual transmission (4 speed). The cluth likage z bar I believe may hit the shock tower but can be made to work fine with a little trimming
  8. Confedneck
    Nov 1, 2002
    5,236
    even with a hydro clutch?? /forums/images/graemlins/grin.gif
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    only if your hydro clutch uses a z bar /forums/images/graemlins/whistling.gif
  10. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I bought some 'E5TZ-18183-A' towers on Monday and asked if they were discontinued, the guy, of course, had no idea but looked in "the system" and found hundreds in local warehouses......if they are discontinued it will be a looong time before the supply runs out in the Phoenix area.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    There not discontinued here in the bay area.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got four of them. They ARE discontinued, but still available.
  13. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I tried all the local dealerships and they were no help on getting any. I found a dealer in Tenn. that had some and he told me he showed plenty in warehouses in Atlanta and Memphis, as in hundreds! Just ordered a set, they are on the way here now, under 10 bucks a piece. /forums/images/graemlins/thumb.gif
    Clay
