fabricating zero rates
Discussion in 'The Garage' started by ryan22re, Sep 11, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    well, i talked to a buddy of mine last week about making some shackles, and he offered up the use of his shop ( http://www.geocities.com/~ksracecars/ksrace.html ). he says he's got all the equipment (lathe, band saw, drill press etc etc).
    so i was thinking...how hard would it be to make a set of zero rates? just some 1" stock about 6 inches long with some holes drilled in it right? bevel the edges and viola! am i leaving anything out?
    plus it will give me a chance to talk $$$ about fabbing a rollcage.
    ryan
  2. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    more questions? how wide should they be? my guess would be as wide as the springs right?
    ryan
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    yes, they should be as wide as the springs. are you planning on just the lift or are you going to move the axle?
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    planning on the lift and moving the axle.
    ryan
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    To move the axle you'll need at least two holes in the zero rate. Both will have to have a countersunk flatbottom hole.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Do a search over at www.austink5.net Someone over there posted a drawing in the last month or so. :cool1:
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    thats where i think his mill/lathe will come in handy. any idea about how big the countersunk holes should be? my guess would be 7/16"- 1/2" or so (assuming a 1" zero rate) deep and about 3/4 inch wide.
    ryan
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    countersunk hole should be big enough to get a socket around the nut and deep enought so the nut is below the surface of the zero rate.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    thanks man, thats just what i was looking for.
    ryan
