Fabricators-What tubing bender?
Discussion in 'The Garage' started by hawglet, Dec 16, 2003.
  1. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    Okay, I have several project that I would like to do which require bending tube. My problem is that I don't have a bender and don't know what one to get. I'm not looking to spend a fortune but would like something that would bender anything from say 1.5 inch to 2.5 inch say a .120 wall. I am looking at building a cage just to give you an idea. What are you guys using?
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have a Pro tools manual bender...
    but I have almost $900 into it...with 3 dies..
    I'm VERY happy with its performance.. /forums/images/graemlins/thumb.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    MTech NE5 with 1.75 x 5.5 and 1 x 3, both 180*+ dies. Wouldn't change a thing.
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    JD2 Model 3 bender with a 1.75" x 5.5" CLR die set. I'm looking at getting a 2" die set sometime in the new year. We got the tube notcher while we were at it...
    Rene
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have a JD2 Model 4 with hydraulics. http://www.jd2.com/ This is the only one I found that will bend up to 2.5" tubing and is reasonably priced. I have used it to bend 2" schedule 40 erw. That is 2.375" OD pipe. I doubt you will be bending 2.5" tube for a cage. So, unless you plan on bending anything over 2" I would go with a less expesive one. That will save you a few hundred $.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    M-Tech NE5 manual bender. 1.5 - 5.5 CLR and 2.0 - 6.5 CLR. The instructions say you can bend up to .250 wall with a longer handle. (I'm gonna find out when I build my x-over drag link) It will be hard to find a bender with a 2.5" die. The main part in the reason for M-Tech is they are local.
  7. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    anybody have a link for the M-tech? I've been shopping around and so far I will be going with the VanSant bender because it is kinda local. Would like to take a look at the M-tech though.
  8. toy4fun
    toy4fun 1/2 ton status
    Sep 10, 2002
    220
    Helper, UT.
  9. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Thanks for the link
  10. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I got my bender through Van Sant...what they don't tell you is that it's a JD2 and is drop shipped from Ocala Florida. So, even though Van Sant is local to you it'll still cost you some $$ for shipping.
    They were very good to deal with though, very friendly and helpful.
    Rene
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    MTECH has JD2 drop ship theirs too. Shipping is very high, especially for the big dies. MTECH sales guy was very helpful too. I actually ordered it and waited to pay for it until it was ready to ship. That was cool!
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, Mtech sells both JD2 and NE5.
    NE5 is made locally in Phoenix IIRC. NE5 is easier to swap dies on due to the extra support spacers (JD2 kinda collapses without the die in place) but it’s almost identical in design. And when I bought mine it came with a free degree ring for the same price as a JD2. Someone recently said they are not slightly higher than JD2 and do not come with the degree ring. I picked mine up at the store, no shipping...
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Another Pro Tools 105 here... /forums/images/graemlins/thumb.gif
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    The model 4 is a completely different animal than the model 3. The die changes are easy. You pull a couple pins and R&R the dies. Takes about 20 seconds. The degree ring is machined into and is part of the lower part of the bender. So there is no additional cost to the bender for the ring. However, the bender alone is $755, then you add the hydraulics and dies, and the price only goes up.
    The reason I went with the model 4 was I wanted to bend tube bigger than 2" and the Model 4 was the only bender that is reasonably priced that can do it.
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    The Pro Tools MB105 is also easy to change dies on. SImilar to the model 4 by pulling the pins and swapping the dies.
