FACTOID: Deciphering Ring Gear Stamping information.... D60 & 14BFF
Discussion in 'The Garage' started by Greg72, Oct 16, 2003.
  1. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I'm not actually able to decipher them for you, but I can give an example of each and give you my best guesses....I will leave it to the rest of the CK5 community to "fill in the blanks" for this topic:
    Let's start with a Dana 60 front:
    Actual stamping sequence reads:
    11 1 79 DANA D 30360 B3R33 41-10
    11 1 79 = Production Date (November 1st, 1979)
    41-10 = Ring Teeth vs. Pinion Teeth...in this case it's a 4.10 ratio
    And now a 14BFF Rear (not from the same vehicle BTW!):
    Actual Stamping sequence reads:
    1 G1 464917 12 45 10 79
    (Could also start "1 GA"...stamping is not clear)
    12 45 = Pinion Teeth vs. Ring Teeth? In this case meaning 3.73?
    10 79 = Date Code? October of 1979?
    Those are my best guesses.... if anyone can help, I'll update this with better info.
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yep, you got it right on the 14ff. 3.73, and it was made in October of 79'.
    -Harrison
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I think it is GM thats what mine says.
    So does that mean that the last 2 sets of digits are the year?
    Mine reads......
    1GM 39777333-9-41 11 73 on the ring
    and..........
    3977336-9-41-GM on the pinion
    That would mean 4.56 GM ring gear from 11-73?
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    30360= dana part #
    b3r33= dana batch #
    /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would believe 41 and 9 means 4.56, yes. /forums/images/graemlins/smile.gif
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    more info on this junk over at POR in the D60 bible... not sure about the ff14b tho...
    j
  7. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    41 and 11 is 3.73.. 41 divided by 11 = 3.73
    Nice to have the date code, now I know what year my 14b is from. /forums/images/graemlins/smile.gif
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I have honestly never seen a 45 tooth ring gear on a 14 bolt before...
    The ratio's I've seen all use a 41 tooth ring gear.
    41/12...3.42:1
    41/11...3.73:1
    41/10...4.10:1
    41/9...4.56
    Greg, could you physically count the ring gear teeth on that 14?
    Rene
  9. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Rene,
    I didn't count the teeth, I just extrapolated what I thought must be the numbers for the "date code" and "gear ratio" based on which numbers looked plausible.....
    I remember that 41 seems to be a common tooth count, but perhaps that's for the Dana 60? The 14BFF has a larger ring gear than the 60, so maybe 45 teeth is believable? /forums/images/graemlins/thinking.gif
    .....like I said, I'm not the expert. But I'll bet someone here IS!
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oops I'm sorry. Its 9-41...4.56. I did the right division, just typed the numbers wrong when I posted it. Let me edit it.
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Greg,
    What I was trying to say was every 14 I've ever looked at had a 41 tooth ring gear. I know some Dana axles use a different tooth count on the ring gear...but 14's seem to be exclusively 41 tooth for some reason.
    Is the second pic of a diff in your posession or??
    I'm not saying it isn't possible, but if you think about it why would GM use a 12/45 set (3.75:1) when they already have the 11/41 set (3.73) /forums/images/graemlins/thinking.gif /forums/images/graemlins/1zhelp.gif
    Rene
  12. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Rene,
    No IDEAR....! /forums/images/graemlins/eek.gif
    The pic is of a new van-width 14BFF I picked up on the way home from BB03.
    I snapped the pic, and took my best guess about the stamping numbers and their meaning. Looks like I will have to wait for more knowledgeable folks to clear up this confusion for us... /forums/images/graemlins/thinking.gif
  13. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Either on this board or Pirate - this 3.75 ring/pinion gear combo was discussed a few months back . It seems that GM used a stronger but noisier tooth count on some van applications. Most GM Vans that came with a FF were work vehicles and its intended useage may have demanded the stronger gear combo and the noise would not have been that noticeable in such a work orriented(sp) application.
    HTH , Tom
  14. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    HTH , Tom
    HA!
    Your comments inspired me.... see link
    http://www.usgear.com/tl/gm3.htm
    They have a chart with all the 14BFF tooth counts.....including (drumroll please) the elusive 45-12 gearset combo!!!
  15. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Cool deal, I knew it was odd to say the least...and had never seen that particular combo before.
    Rene
