Factory 6.2 oil cooler lines from block to radiator, 68.5" rear driveshaft
Discussion in 'Parts & Trucks Wanted' started by BlueBlazer, Dec 1, 2003.
  1. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Factory 6.2 oil cooler lines from block to radiator, 68.5\" rear driveshaft
    Anybody have these things, let me know. Thanks
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: Factory 6.2 oil cooler lines from block to radiator, 68.5\" rear driveshaft
    If you can't find them used. Find a place that make hydro. hoses, they should be able to make some.
  3. BlueBlazer
    Feb 15, 2001
    1,940
    Tried that, they want 85 bucks a line.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Do you still have the steel ends? I once used compression fittings to adapt the steel line to a pipe thread and had a Napa make generic hydraulic lines with pipe thread ends. Came out a lot cheaper than custom fit hoses.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thats about what the dealer wants. Here are the gm part numbers:
    Flex Lines
    14029291
    14029292
    Hard Lines
    14041292
    14041293
  6. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    I have the cooler lines. They are off a Military blazer, they have a neat little valve to take test oil of a line. PM me back /forums/images/graemlins/thumb.gif
  7. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    what kind of d-shaft?
    Slipyoke or not, I have a couple extras around and so do some friends. I'm in STL so shipping might be reasonable.
    Give me dimensions open/closed and what size joints on each end and I'll see what I got.
  8. BlueBlazer
    Feb 15, 2001
    1,940
    68.5" from yoke to yoke with truck sitting on the ground, so there would have to be sufficient travel each way from this measurement to assure no binding or anything. It has to be fixed yoke and the application is an 87 K30 with 465/205 with fixed yoke if that helps. Thanks
  9. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I measured every shaft I have and they are all too short. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Seriously, my 79 3/4 has a 350/465/205 and it has a 2 piece rear shaft with a carrier bearing. This might be what you are looking for, not sure if you will find a 1 piece that long.
    good luck, sorry i couldn't help. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
