Factory ammeter to factory voltage gage swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Aug 6, 2001.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Has anyone tried this? I did a search on ammeter, and didn't see anything. I'm interested to see what you did, before I delve into this project.
    <a target="_blank" href=http://fwp4x4.rockcrawler.com>fwp4x4.rockcrawler.com</a>
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Should be a lot easier to make that swap than going from a voltmeter to an ammeter. An ammeter requires alot more heavy gauge wiring to be installed properly. Needs more of a direct contact with the alternator/battery. Whereas with a voltmeter you can tap into any 12 volt source in the truck to hook it up...a groundwire hookup and maybe power for a light and thats it.
    '73 K5
    Chevy good...Ford bad
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I know what your saying, thanks. I'm puttin a voltmeter into the factory cluster in place of the ammeter.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Top. Anybody else have ideas.
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Well, I know that my new autometer guages that took the place of the factory one I sold you, all I had to do was hook up a 12 volt wire, I got it from the fuse box under the Ign section, so the guage only gets power when the key is on, and then gave the guage a ground wire. Pretty simple, Now I know you don't have the posts marked, pos or Neg, so you'll have to do some expirmenting, but it shouldn't be too hard. Good luck.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The voltage reading should come right off the alternator. The only concern I have is the other circuits that may be using the ammeter for power (since it's in series). I don't fully understand the schematic for that particular application yet, but as I dig deeper, I will. The whole reason I want to do this is I can tell right away I have something up if the voltage is less than 13V wiith the engine running. The ammeter thing may not be correct as far as I can tell. GM had some definite problems with acceptable wiring practices. &amp;%$*&amp; Bean counters.....LOL.
  7. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    The new "K5 Garage" at Lil Daves garage has all the wiring diagrams from 73 up and about 3 NOS circuit boards to convert...lol.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
