factory cruise module,where is it........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gotmud?, Apr 30, 2002.
  1. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    what's it look like and are they a pricey p.i.a. to replace?
  2. dyeager535
    26,980
    Its a black box IIRC, around the gas pedal. Maybe 6x4"? Why do you need to get at it? Those printed circuit boards GM used seem to be real rugged pieces, and its not likely that its failed if thats where you are going with this....I should scan in the service manual section on diagnosis of the cruise control system, its quite good.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    It's more likely that you have a vacuum problem. That's easier to check, too.
  4. gotmud?
    Feb 23, 2002
    1,172
    up north
    cruise don't work, stalk is brand new and i was told it's probably the module. think they were just guessing though.
  5. dyeager535
    26,980
    Of course! Easiest thing to do is blame the computer components! : ) I have personally never diagnosed one of these things, but since the Cruise module/harness is almost entirely stand alone (VSS might be shared depending on year) its not going to be too *tough* to diagnose.
    Again, never having worked on cruise, are you sure that VSS is still hooked up? I've pulled a dash out and forgot to bolt the VSS "eye" back up to the speedometer head.
    If no one else volunteers, if I get a chance tonight, and its not too long, maybe I'll write up the diagnosis procedure for cruise out of a service manual
  6. McD Blzr
    McD Blzr Registered Member
    Apr 23, 2002
    16
    San Jose, CA
    Hey, I cold use the diagnosis too. Only thing I have is the Haynes manual. The stalk works fine for the washer and lights, so I'm hoping it is just a loose connection.
  7. gotmud?
    Feb 23, 2002
    1,172
    up north
    You Da Man/forums/images/icons/wink.gif
  8. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    looks like mine was disconnected when the original owner put
    another motor in it i would love to get it working since i do alot of highway driving.
  9. dyeager535
    26,980
    heres probably the most pertinent page
    http://yeagerd.home.mindspring.com/cc.html
    http://yeagerd.home.mindspring.com/TablePics/cc1test.gif btw, is the link to the original sized one lol (at least its easy to read for your grandparents)
    I'll work on getting the rest of it up, but its frustrating not having much graphics skills, the quality of the scan is better, and I'd like to bring the image size down (your going to have to wait to view those) but I figure it will help some. The connectors usually have the letters on them for the wire (like "F" as the chart mentions) but if not, I'll have to scan in the other pages.
  10. McD Blzr
    Apr 23, 2002
    16
    San Jose, CA
    The first link printed out just fine.
    I'll get out my continuity checker in the next day or two and give it a go.
  11. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I have the diagnostic flow chart and wiring diagrams from AllData for cruise control. Send me an email if you want me to scan it.
