Factory dash clock??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chalet 170, May 25, 2002.
  1. Chalet 170
    Chalet 170 Registered Member
    May 15, 2002
    19
    Bay Area, Ca
    What is the most common cause of failure? I would like to get it working, but don't know what to look for.
    Doug
  2. abusedtrucks
    abusedtrucks Registered Member
    May 11, 2002
    76
    Upsala , MN
    I thought these things were busted right out of the crate.
    Put a picture of your significant other over the space that the clock is supposed to be.
    Sorry I don't have any real advice. I'll definately be watching this one for a fix though. I don't think I've ever seen one that works.
    Good luck.
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You guys got me thinking.. I bought a second K5.. The motor was shot in it.. But it did have a clock in it.. I finally got it running today and I went out to look at the clock..It is working...LOL Guess I should set the time and see if it holds it...LOL
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Mine would work sometimes and sometimes it wouldn't so I disconnected it eliminating any possibly of it draining the battery
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    My '85 K30 has the factory dash clock and it works just fine and dandy.
    The only problem I have with it is the little chrome knob thats on it for turning it is broken off and a new one just does not seem to hold on. /forums/images/icons/frown.gif
    I'm always needing to use vise grips to clamp on the little "turner" and adjust the time with the clamps. /forums/images/icons/tongue.gif /forums/images/icons/laugh.gif
  6. tagurit
    tagurit Registered Member
    Mar 19, 2002
    25
    Nth E. Louisiana
    the clock in my 81 worked like a charm up until about 2 months ago when my gf decided to change the time to match her watch... the damn arm broke.
    It still tells time but it's off about 6 hours. I guess I could pull the battery cable until the real time and the one on the clock match, haha.
  7. dyeager535
    26,980
    I just think they are crappy clocks. Seriously, not many of the GM clocks of that style, whether in cars or trucks, seemed to last very long. You might check some of the restoration catalogs, maybe for Corvettes or Camaros, I *think* some company was rebuilding them, with newer/better components. But thats a lot of work for a truck clock lol.
    Another idea is to use a GM digital car radio, then you could just get rid of the stock clock entirely.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have the same problem that Wes has. My clock has alway's worked,and holds the correct time. I just to get the little knob to stay on. /forums/images/icons/smile.gif
  9. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Mine wouldnt keep time so I disconnected mine as well. It also used to bug me to death when I was camping,(we usually sleep inthe 'burb) and just heard "tick, tick, tick" all night. Man that got annoying!
