factory gears
Discussion in 'The Garage' started by win717, Jan 31, 2004.
  1. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    Anyone running factory rear gears in there blazer?
    I have a 79 blazer 205 transfer case 4 spd..with as far as i know factory rear gears,,1st 2nd gear is fine but i hot 3rd it stumbles can hear the valves taping it jerks....once i get her going pretty good it seems better..but as soon as a hill comes up I need to shift into 2nd before i hit the top..not sure if my rear gears are to high or i should look for something else
  2. win717
    Mar 8, 2003
    60
    PA
    anyone??
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    What size tires are you running? do you know what the gears are?
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    It depends on your tire size. If you're running stock 31" tires, your gears will be fine. Stock is usually 3.07 for the 12 bolts and 3.08 for the 10-bolts. I think 79's have the 10-bolt.
  5. win717
    Mar 8, 2003
    60
    PA
    I'm running 33s with 4inch lift, gears..really don't know..i was just told that they were factory..when it warms up around here i can get under it and found everything out
  6. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    If I had to guess, You probably have 3.08's. So with the larger tires, I'm not surprised you have to down shift. I have 3.73 and 33's on my 76. Most of the time it's fine, But there is one hill by my house That i have to downshift for. My 87, with 31's and 3.08 Can't climb anything without downshifting! Both these trucks are 350ci, 4spds.
