Factory Hydraulic clutch assem.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Captkaos, Jun 5, 2000.
  1. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    Anybody here have a factory setup hydraulic clutch assembly?
    If so, do you have the part numbers and/or pictures of the setup. I would like to know what I need to get pertaining to the clutch slave cylinder and the actuation.
    Chris Lucas
    http://www.wwisp.com/~captkaos
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Hey Chris. I'll try to remember to snap some shots tonight and send them to you. I still owe you a favor. It's pretty easy setup. Just a resivour with a long tube down to the push rod.
    Shawn
    87 K5
  3. Captkaos
    198
    Birmingham, AL
    Thanks Shawn.....
    I really appreciate it. I particularly need to know where the reservior hooks up to the firewall and what I need to do
    to the pedal assembly to make it work. Is it just a rod that goes in the normal mechanical rod slot?
    You still owe me a favor? From what? I thought I owed you one.... :)
    Chris Lucas
  4. joe84bb
    joe84bb Registered Member
    May 16, 2000
    45
    Florence, AL
    Re: Thanks Shawn.....
    I swapped from a 700r4 to a muncie, so I had to hold everything (bracket and pedal assembly) up under the dash, mark the best spot, and squeeze a drill and hole saw under there. I would like to give you some detailed measurements, but I really only had one place where everything would fit. It was pretty much a SWAG. Scientific Wild A$$ Guess.
    I know just enough to know that I'll never know enough.
  5. Shawn
    1,753
    5
    5280'
    I emailed those pictures to you. It's hard to see just from the pictures but I hope it helps.
    Shawn
    87 K5
  6. Captkaos
    198
    Birmingham, AL
    I appreciate it Shawn. That helped out alot. I do have some questions, look for email.
    Chris Lucas
