Factory Oil cooler lines
Discussion in 'The Garage' started by walt88, Sep 22, 2002.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I was driving down the parkway cranking at 75 mph. All of sudden my cab is full of smoke. /forums/images/icons/shocked.gif
    I pulled over and checked. I found that the front driveshaft and tranny and tcase were spattered with fluid. I called the tow truck and didnt really take a closer look.
    My dad drove by and seen golden fluid on the flat bed of the tow truck. Probably oil, after it smoked I shut the truck off as i was coasting to prevent any further damage.
    I was wondering if the oil cooler lines can be fixed, what has to be done? Are you better off eliminating the oil cooler in itself? I dont tow at all.
    I'll update when I find out exactly whats wrong. /forums/images/icons/tongue.gif
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If the problem is with your oil cooling system, it's probably either a connection or the cooler itself. Those are the two weak points in the system.......
    Let us know what you find.
  3. blazin90
    blazin90 Newbie
    Aug 19, 2002
    3
    pioneer california
    i am having the same problem called chevrolet they dont make the lines anymore i think i'm gonna remove it alltogether
  4. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    Well I didnt find anything having to do with oil cooler in LMC either.
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I had to replace one of mine a couple months ago and the chevy dealer ordered it for me, had it in a couple of days.
  6. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    could just add an after market cooler, or if it's just the lines, a hydraulic shop should be able to manufacture these lines reasonably.
  7. Grim-Reaper
    7,385
    Atlanta
    Well first off the oil cooler lines run down the driverside. They mate to an adaptor between the Oil filter and block. So knowing that it can't be the oil cooler because the drive shaft is on the other side of the engine.
    Must be tranny cooler lines. No you don't want to remove that. Fix it. That's a pretty common set of lines and should be an easy junkyard score.
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine just pooped a chicken on me this weekend. It seperated where the rubber and the steel meet. I removed the system and went mud bogging on Sunday. Didnt notice a change in temps.
