Factory quad shock
Discussion in 'The Garage' started by jess, Mar 22, 2004.
  1. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    Is there any benenfit to utilizing the factory quad shock setup on my K5 build up or should I cut if off? /forums/images/graemlins/hack.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Cut it off... /forums/images/graemlins/grin.gif...Mine came with the quads and it performs much better with just one shock at the corners...
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    you can run just one shock on these(no cutting needed), unless you want to /forums/images/graemlins/hack.gif
  4. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    I had the factory quads when I got the K5. After a 4" lift it was handling not up to par. I put the quad set up back on (new longer shocks) and a dual stablizer and liked the difference. Just my 2 cents /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i just think it looks cool /forums/images/graemlins/thumb.gif
  6. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I got rid of it I like it better now /forums/images/graemlins/waytogo.gif
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    quad shocks??? anyone got a pic?
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Quad shocks? Quad=4? 4 shocks at each corner? That sounds expensive/wasting. Unless you just drive over those mall curbs /forums/images/graemlins/rolleyes.gif
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Quad shocks were an option. I've only seen them on the 80's trucks but it may have also been an option in the 70's too. Anyway it gives you 2 extra shocks in the front. So you have 4 shocks up front instead of just two.
  10. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    They are factory on my 91Jimmy /forums/images/graemlins/whistling.gif
  11. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    my 77 has the mounts, but i dropped down to just running two shocks. 4 just plain hurts(especially since they were all rancho 5000's...ouch).
  12. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    If you run only 2 (long ones) and decide at a later date you want to run 4 (add 2 short ones). Will the 2 (long) shocks you already have still work or do you have to go buy all 4 again. /forums/images/graemlins/thinking.gif
  13. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    they would work if i want to go back to 4(never)
  14. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    80's K5 include 90s and 91s...I know it's strange but trust me on this one...
  15. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    quad +4 I knew that. i agree withe the rest of yopur reply though. i thought it rode rough now.
  16. jess
    Jan 4, 2004
    27
    CT
    Okay, maybe I'll keep the bracket there incase the singles don't work out.
  17. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    I went with only one shock instead of the quad setup, but with a soft worn factory springs, the body roll sucked on cornering. so i went back to the quad set up
  18. big jimmy 91
    Feb 21, 2004
    639
    I have pics.
    How do you post them?
    Please and thanks
  19. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yeah i ran with singles on each side once, but didn't like the handling performance and of course the sway from side to side, so i went back to the quad setup and is better, but still wasn't "right" so i called the place where i got my lift kit from, and they informed me as to whjat kind of shock to get to help out with the ride, they sold me nitrogen gas charged shocks and it is much better, alittle firmer, but much better control.
  20. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    you can put em in your webshots or you can upload em at villagephotos.com and post em directly on the thread by clicking the image button (below and right). i forgot to say you will need to right click the pic and copy paste the url from the proprties tab.
    69k5
