Factory Rear CV drive shaft? (Double cardon)
Discussion in 'The Garage' started by camarossguy2, Jul 27, 2006.
  1. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    I recentally lost a u joint in my drive shaft exploded and now im trying to find a replacement, but all im finding are regular ones.
    My 89 had a CV rear shaft. Was it factory? looks old and rusted...looks factory.
    is there a big difference between a CV shaft and a regular one for a truck with 8'' or so of lift?
    thanks
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    3/4 ton axles CV shaft, 8" lift? You definatly have a custom shaft(s). Post up info on axles/drivetrain. Maby someone here can give you a # for a ujoint that may fit. You could also take the driveline down to your local driveline shop and tell them what your setup is they will be able to get you what you need.
    CV joint or double cardan drivelines work better at steep angles and give less wear and tear. than regular 2 joint DLs
    **PM Drivelineman He will help you
  3. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    I bought the blazer with just a 6'' lift and stock everything and thats how it came, with those Drive shafts. I will post a pic of whats left of the old one, but it looks factory.
    Also the retard i bought it from didn't know about them.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    hmmm yeah i need info on this too...
    I have a factory rear 2 piece shaft.. lowered the carrier bearing a few inches but the shaft angle is still steep... I can actually make the rear tires hop if I launch hard enough :haha:
    scares people next to me....
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have never seen a stock CV shaft on the rear of an 89 Blazer so I do not think it is stock. A PO prolly lifted it 6" and had vibrations. He may have had a CV joint shaft built for it or went the cheapo route and had a CV joint installed in the stock drive line. Does it still have a slip yoke? Or do you have a SYE?
    Lifting a blazer over 4" usually involves driveline work of some kind. I had my rear shaft lenghtened slightly and rebuilt with stronger lighter DOM tube To get rid of a drive train viabration I got with only a 4" lift. Its smoother and stronger than stock now.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Thats because no stock chevy truck ever used a rear cv driveshaft...
  7. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    Here is whats left of my CV shaft
