Factory rubber body mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Aug 21, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Has anyone replaced the factory style rubber body bushings (not polyurethane) and know where the best place (cheapest), besides GM and LMC to get these? Thanks.
  2. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    Don't waste your time on factory mounts. Get the polyurethane mounts and you won't look back. The are only about $100 at most. Well worth it. I have them and they are great.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  3. Predator
    Jun 19, 2001
    130
    OKC,OK
    But don't they ride rougher and squeek unless lubed?
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yes, they ride rougher, as in, they don't cushion as well, but they will last for a very long while, if not forever!! They really help control body sway a little too. That's the one of the reasons whey I like poly. Also, poly is much cheaper than the rubbers for some reason. Just put some grease when you install, and you shouldn't have a problem with squeeking.
    Boss
    89' 1 TON of FUN K5
