Factory skid plates????
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rusty68, Aug 22, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I was just wondering how many of your guy's rigs had the skid plate on the tranny/transfer case crossmember? The cross in my truck does not have one. But I was digging threw some of my parts today and found a crossmember that does. Its kinda weird though. It just looks like a piece of 3/8 plate riveted accross the bottom. But what I found odd was that there is no accesss to the support bushings. I cant even see how you would bolt the tranny down to the crossmember. Someone care to try and explain this to me?
  2. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    My blazer has a skid plate that I believe to be factory, It bolts to the lower portions of the cross member and stick back and covers the transfer case. If you want to get to the trans/mounts you have to remove it. there are 4 bolts that hold it in place. hope this helps /forums/images/graemlins/thumb.gif
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Also, on this vintage of truck, they used a second frame crossmember behind the transfer case when the skidplate option was installed. The skid plate attached to both crossmembers.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup I have the dual crossmember/skid plate. I also HAD a factory gas tank skid.
  5. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    hmm so it unbolts eh.. The one that I currently have as those large blind rivets similar to whats holding the frame together. Im wondering how it was attached in the first place:) But I may grind them off and bolt it to my crossmember. Never can have to many skids....
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    It has to unbolt so that you can change the clutch or get at any other tranny or transfer case stuff...
  7. mkmiller
    mkmiller 1/2 ton status
    Oct 31, 2001
    306
    Magnolia, Arkansas
    rusty68-The skidplate you are describing is from a 67-69; from 70-72 they made the ones that bolt to the crossmembers. I have one like you described on my '68lwb4x4, from what I can tell it would serve no purpose but some said it was to protect the carrier bearing on lwb trucks(mine has a 1 piece driveshaft). There is a guy over at the 67-72 truck board on the 4x4 page that is selling the newer ones 70-72(home made with all correct bends and holes)for like $25+ship. It is actually under a thread I started titled "Skid plate pic".
    Catch ya later,
    Matthew
  8. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Yea, I checked that thread out. Makes sence that it was a bearing skid because there is no way it could have been for the tranny, even though they appear identical. Also since the plate is in the middle, I was confused as to what part of the tranny/transfer case the skid was supposed to protect as the lowest point is offset towards the pass side. I guess I need to shut up and nod my head and drink my coffee. /forums/images/graemlins/smile.gif
  9. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Father in laws 71 k5 HAD the factory skid plate for the fuel tank...he put in a 40 gallon monster years bak but we still have the skid plate. Until i saw the plate i had no idea they made them back then.
    DW
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    My Dad's 75 had a gas tank, t-case, and front/rear diff skid plate from the factory! /forums/images/graemlins/thinking.gif
