Factory Spoiler Installation
Discussion in 'The Garage' started by 86IROC, Feb 10, 2006.
  1. 86IROC
    86IROC Newbie
    Feb 8, 2006
    Ohio
    Hey I got an 83 fullsize Jimmy ( Seirra Classic) I recently purchased a factory spoiler, with no bolts. What bolts can I use to install this thing?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Spoiler?? What, for the roof?? You need more downforce for high speed stability?? I would just get some from hardware store and put some sealant on them. Or are we talking about a different spoiler?? :dunno:
  3. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i think he is talking about the "air deflector" that came on some blazers..not really a spolier, its susposed to help keep the back window clean....wether or not it actually works..:dunno:
  4. dyeager535
    26,982
    191
    The factory used "well nuts" with stainless bolts that IIRC, match the countersink in the spoiler. You can get the well nuts at really good hardware stores.
    These tops are so easy to find, if you aren't in a huge hurry, you might just find one that already had the spoiler on it, and use the new top.
    You could try something that went through both pieces of the fiberglass, but I suspect the inner surface isn't flat where they'd protrude.
    And yes, in my experience, the spoiler helps a great deal keeping the rear window dry/clean, and keeping exhaust out while the vecicle is moving with the rear window down.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Exactlly, I can drive mine at any speed and have no problems with exhaust fumes with the rear window down.
    Ira
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Hmmm.... Never seen one in my neck o the woods...
  7. dyeager535
    26,982
    191
    And as an aside, not quite correct before, the factory didn't use well nuts, but that's the closest equivalent I was able to find. They used the same type of nuts that you see holding the side view mirrors to the door. But since the well nuts are rubber, they will seal against moisture. Since you cut into the space where the metal frame of the top resides, that is a good thing.
