Factory tach and HEI
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, Jan 18, 2003.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    I've been reading alot about how a factory tach from my 72 k5 will read to high when I convert to HEI. Is there a filter that will make it ready correctly or do I have to buy a new tach and install it in front of the onld tach on the steering column?
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Remove the dash and adjust the screw in the back until it reads correct (cant remember if I had to remove the tach from the cluster to do this), use a timimg light for reference. I did this a while ago, I run an EFI distributor with external coil now and it still works fine
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    BIG RAY!!!! /forums/images/graemlins/rotfl.gif
    Tsk...tsk..... that adjustment will only correct your tach for a specific RPM....the overall error will still be quite high.
    I had a schematic posted in my gallery for a long time for a simple circuit that will solve the problem. I ran out of space and deleted it....if someone else has it, maybe they can post it....or PM me and I'll e-mail it to you directly.
    Oh what the hell.....here it is:
    Oh and here's a post that covered this topic in detail....started originally by "Yours Truly"!!
    http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=365281&amp;Forum=firstgen&amp;Words=HEI&amp;Match=Entire%20Phrase&amp;Searchpage=11&amp;Limit=25&amp;Old=allposts&amp;Main=361115&amp;Search=true#Post365281
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks for the schem. to bad i cant read it. /forums/images/graemlins/grin.gif but thats why i have my dad /forums/images/graemlins/grin.gif
    nathan
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I had my bud make that up and it didn't work....need to have him re-do it....
  6. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    Thanks a bunch. I wasn't looking forward to loosing the stock look inside.
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    You could also put a second generation Camaro tachometer into it. That's what I did with mine and it reads much better than the original tachometer (not to mention that it's useful to where my engine is cammed). It is still not totally accurate (reads high, but not by too terribly much, definitely less accurate than the 1970 Firebird tachometer I have in my Trans Am), but it's better than the stock truck tach. It doesn't look absolutely stock, but if someone glances at it without knowing, they might think that it belongs there.
    There's a picture of it at: http://www.geocities.com/MotorCity/Downs/1963/BlazerPix.html
    Scroll down a screen or two and you'll find it.
  8. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    Thanks Steve. I remember reading about that on a post last year. Seems like you had a hard time finding the tach you wanted. Did you find it in a junk yard?
  9. Steve_Chin
    Mar 6, 2001
    1,126
    Yeah, it's a J-yard part. I got it out of a '77 Camaro. I think they changed the style in '78 or '79. If you want a really cool tach, you might want to get one out of a '70-'74 (I think) Camaro. It reads to 8K, where the later one reads to 7K. Those tachs are also repopped. Classic Industries sells the repops. Be warned that you have to cut up the face of the tach, though. I also took the flex circuit out of the Camaro and wired it into the Blazer's flex circuit, and cut the harmonica connector out of the Camaro so that I could properly wire the tach into my ignition.
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Kiley,
    Here's another option.....except for being a TON of work, and not being 100% original, you might like it:
    I re-used the stock speedo and fuel gauge, but everything else is Autometer stuff. I ended up with Tranny Temp, Water Temp, Oil Temp, Oil Pressure, and a Tach that actually reads correctly.
    Just another option if you want to keep it sorta "stock" looking!!!! /forums/images/graemlins/cool.gif
  11. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I think I may have generated that filter schematic...it's from the stock Chevy filter...the one error I see is the cap on the left should be a .15 microfarad, not 15 microfarads. Sorry if this lead anyone astray..... /forums/images/graemlins/blush.gif
  12. Michael
    1,576
    Sherman, Texas
    Here is a re-draw:
  13. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    Thanks, that looks great. I bought a tach that reads to 8K to strap to the steering column until I feel brave enough to crack open the instrument panel. I'm changing over to HEI on Monday, my first upgrade!I recently bought a 71 c20 longbed for a daily driver and while I was shopping I found a 70 CST that had a factory vacuum guage on the inner right side of the guages, the one that's always blank.
