Factory Tach Calibration Issues
Discussion in 'The Garage' started by mosesburb, Oct 16, 2003.
  1. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I have a factory tach for a 76ish truck that reads higher than what the engine is actually spinning. At about 850 rpm, the tach reads about 2000 rpm. Took it to the local speedo/tach service facility and they said there is nothing that can be done with it. A person needs a dumptruck full of money to afford a new one, so I was wondering if anyone had ever calibrated/fixed one before??
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    There was a factory tach in the for sale forum on this site for $40 or something like that. jjlaughter's post I believe.
  3. kennyw
    Jun 9, 2002
    13,224
    94
    Oh, make sure you have a good ground and connector on the HEI as well before you do anything else. /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,980
    I have one for my truck, and my dad has one in his truck. (both the 80's style)
    Our tachs aren't as far off as yours, but I can't come up with the reason his and mine are both off. It's not a simple difference in actual vs. advertised tire size, or incorrect assumption of gear ratio, the tachs are simply incorrect, which is kind of odd IMO.
    Does your tach "zero out" when you turn the key to "run", before you actually start it?
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Hate to be a smart azz, but take it out, and bend the needle, so it correspond's with the real rpm. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
    Seriously, take it out, remove the needle off the shaft, and rotate counterclockwise, and put it back on. /forums/images/graemlins/grin.gif
  6. ericguy320
    ericguy320 Registered Member
    Dec 28, 2002
    23
    NC
    like kennyv said make sure you have a good ground thats what mine was dooing and i found a corroded wire
  7. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Yes, all the wires are good. When it was installed I had made a new harness for the engine compartment and under the dash because of previous owners butchery. No problems with grounds. I even hooked up a raggedy old Sun Tach to it and it read right around the same as the Snap-On timing light/tach.
  8. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I maybe be thinking of something else but.. In the factory harness isn't there a resistor or something in-line with the tach wire??
