factory tach dash question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big d, Feb 9, 2002.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    ok, just purchased through the mail a used factory original tach dash.(obviously without seeing it first)- the dash housing is busted to hell and unserviceable. also pigtail wiring harness is cut. 1st question, in all the resto catalogs i find, replacement tach wiring harnsses stop at 74', will it work for my 79' ? 2nd question, will my present (current) dash housing work with a swap of the print board, guages, and face shield (the boughten one has a nasty scratch). is this going to be an easy install, is there any other considerations to worry about ? should i refer to a service manual to install this, are the wires easy to i.d. ? or should i have it professionaly installed to make sure everything is correct ? any and all info will surely and greatly be appreciated !
    darrenolander
    galva,il.
    1979chevycheyenneblazer
    350/350
    gettin'down on all fours, 4 a'little
    x4 play !
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The tach you bought should work fine with your truck, I would not worry about the harness. Just run a wire from your distributor tach connection and if you swap the printed circuit board that sould give you power to the tach. If you need further wiring info, I could look it up or scan a section of the wiring diagram for you when I get home. My home email is wmark17@qwest.net
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    MJ knows how to rewire for the factory dash. I think he has diagrams. Send him a PM and he'll hook you up.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www.customtruckshowcase.com/forum/showthread.php?s=&amp;threadid=664>1985 wiring diagrams</a>
    <a target="_blank" href=http://www.customtruckshowcase.com/forum/showthread.php?s=&amp;threadid=818>1973-76 wiring diagrams</a>
    whats the year splits for wiring, 76-77 is the glass to plastic fuse, is there another split in the 80s as well?
    I would bet the gauges would swap but it may depend on how far apart the years
    I just had to figure the pin placement differences
    formerly 77chev
    still a jerk though
  5. azblazor
    May 5, 2001
    1,953
    Check out this thread <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=311927&amp;part=1#Post311927>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=311927&amp;part=1#Post311927</a> it has some info and links that might help you.
