Factory tach/instrument cluster
Discussion in 'The Garage' started by AZ79K5Project, Mar 17, 2007.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Can an 84 factory instrument cluster w/tach bolt into a 79 w/out a tach (and work)? What mods need to be done?
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The wiring harness is different. That is, where the wires are routed to the big plug are in different places due to the tach if I remember correctly.
    If you get some good wiring diagrams, it shouldn't be that hard to fix it.
  3. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thanks.
    Anyone have a link to a factory cluster diagram for this? 84 Chev P/U.
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Haynes manuals have a good set of wiring diagrams, and where individual wires land in the connector. I plan on doing the same, putting an 81 cluster w/ tach in my '73. It's just gonna be tedious tracing out different wires on the diagrams to figure out what needs to go where.
  5. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thanks - I just found the harness diagram in my factory service manual. I've got a nose bleed trying to read that thing.
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Actually, in 79 the wiring changed, and stayed that way until 1990 when they switched to an electric speedo. Assuming both trucks have oil, temp, and volt gauges, not idiot lights on one or the other.
    You will need to switch the sending units from the newer engine over to the older one to keep the gauges reasonably accurate.
    The tach wiring is totally indepenant from the rest of the cluster's wiring, so you'll need to move the tach harness over as well.
    The clusters wiring was the same from 73 - 76, then 77 & 78, then 79+. They did change color in 1980, and began being equipped with speed sensors in 83 when the electric cruise system was introduced.
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thanks for the information. It gives me some direction.
  8. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    I've heard that if you mix years it may cause a fire. Something about the circuit boards not being compatable. Don't know if it true. Anybody have any experience with this?
  9. dyeager535
    26,979
    Had a friend throw a tach cluster into an early truck, IIRC it didn't burn, but he got a lot of smoke and toasted the cluster somehow.
    As mentioned, it has to do with the wiring. It's actually pretty simple, even without a manual. Pull your cluster, and trace the wires on the PCB. If they all go to the same place, no problem. It's only a 16 pin connector or so, and not all the terminals are used every year.
    It's not an incompatibility issue, all the cluster connectors are the same, it's just the way the wiring and PCB are arranged.
  10. Russell
    Jun 23, 2000
    7,923
    333
    The major interchange issue rises with mixing up volt and amp gauges. From 73-76, they ran an amp gauge, which measures current, and is hooked up inline with a positive power wire, then from 78-87 they ran a volt gauge, which measures potential difference between a hot wire and a ground wire. If you mix them up, it will cause an electrical fire by overloading the coils in the gauges, and overheating them till they start burning.
    Technically speaking, the basic wiring pinout change was made in 77, when they switched to the volt gauge, but in 77 & 78, the trucks still had mechanical oil pressure gauges. In 79 they were changed to electric gauges, and the wiring for the gauges was adding, making the final wiring change until the electric speedos were introduced in the burbs / K5s etc.
  11. dyeager535
    26,979
    Have you looked at the '87+ stuff?
    I know the PCB is greatly simplified on the '90-91 stuff, but of course the electric speedometer was a major change anyways.
    Just curious if the PCB was improved before the electric speedo. It only uses about half the wires on the connector because all the power feeds and grounds are on the same pin.
  12. Russell
    Jun 23, 2000
    7,923
    333
    I'm assuming he is working with a 73-87 truck, so I didn't get into the 88+ stuff, where yeah, things definitely changed again :D
  13. dyeager535
    26,979
    I'm talking '87-89 R/V, our body style. But going off topic. :)
  14. Russell
    Jun 23, 2000
    7,923
    333
    Ah yeah, good point. Haven't really delt with the R/V stuff much. I can definitely imagine that the 90 - 92 stuff is quite different with the electric speedo, but didn't know that the pinouts changed in 87 with the K5s, Burbs etc...
  15. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    Are you sure 77 - 78 still had the mechanical oil gauge cuz my 78 just has the wire hooked up.
  16. Russell
    Jun 23, 2000
    7,923
    333
    Suppost to, but there are always exceptions :)
