Factory tach stopped working
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Aug 9, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I pulled my driveline to have it balanced and after reinstalling i noticed that my factory tach is not working. is it electric? where does the wire go. I assume i accidentally disconnected something. thanks
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You have a tach? is it a diesel? do you have a little gas guage in the fourth hole on the left? /forums/images/graemlins/ooo.gif
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  3. zach78k5
    May 14, 2000
    406
    not a diesel but my gas guage is on the corner on the left. I think that is quite rare. until i saw this blazer i did not know that they came stock with a tach.
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    They don't, thats something custom ordered from the factory.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Nope, back then it wasn't "custom". You just had to check the correct box on the order form, pay the extra $100 or so, and your truck would arrive with a factory tach in the dash. /forums/images/graemlins/cool.gif
    I had a '77 that had a factory tach. The tach didn't work when I bought the truck. I found a condensor mounted on the firewall, near the brake booster, that had one lead broken. I fixed the broken lead and the tach worked again. /forums/images/graemlins/thumb.gif That was about 22 years ago, but if I remember right, it was connected between the tach feed from the distributor and ground. So just follow the wire that comes from the "tach" connector on the HEI and see where it leads to.
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Out of curiosity, does anybody make a replacement tach for that option? I was hoping to install a tach in that spot and move the fuel guage at some point but it seems everybody makes all the replacement guages except that tach.
  7. dyeager535
    26,977
    Nope, and they aren't listed in the GM parts book I've got either. ('85-86)
    Don't know as anyone sells replacement tachs, only repairs them.
  8. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    the parts truck im buying has the factory tach.... i cant wait to get this truck.. i hated having such a big fuel guage!!!!!
