Factory Tow Hitch and Shackle Flip Interference problem ??
Discussion in 'Tow & Trailer' started by 88Silverado, Dec 22, 2003.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Thought I would try this forum.
    Installed my Shackle Flip but the brackets interfere (cover) the forward frame holes used by the factory hitch.
    I dont want to cut the flips and dont know if I should try (or can) re-mount it a few inches farther out.
    Is there a better hitch to use which has shorter mounting points?
    Thanks /forums/images/graemlins/grin.gif
  2. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I just used a piece of plate the same thickness as the flip to space the rear down. Then drilled through the shackle flip. Not sure if this is what your looking for but it's one solution.
    Mike
  3. 88Silverado
    Mar 13, 2003
    2,664
    I thought about that, hated to drill thru the flip yet cant see drilling another 4 holes on the frame either. I dont know if all the hitches are setup for that hole spacing where I have to drill thru the flip.
    Thanks for info /forums/images/graemlins/thumb.gif
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Mike
    Did the same thing and it worked fine. /forums/images/graemlins/thumb.gif
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    never thought of drilling and spacing. i decided to take the cutoff saw to the brackets. it was kind of painful cutting a 2x2 square out of 200 bucks of brand new hardware, but i decided that it wouldnt sacrifice strength. getting all the bolts in together was tricky, i ended up flipping the hitch bolts upsidedown to make room for the bracket bolts.good luck
  6. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    There's nothing quite like cutting up a brand new part! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
    Mike
