Factory tow hook placement...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Oct 19, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    O.K. did a search and did'nt find any info...got a set of factory hooks for my '76 K-5.. looked under it today and the hooks do not line up with any existing holes on the frame... 3 3/4 inch between each hole on the hooks (center of each hole).. 3 1/4 between any hole in the frame... do I bolt to one and drill the other... Thanks... also are these hooks strong enough compared to aftermarket?? /forums/images/graemlins/k5.gif
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i've pulled and been pulled by mine and they're holding up fine. yeah i think i'd just drill a new hole for em.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I don't remember exactly, but I believe the 80's style hooks won't fit on the 70's style trucks,
    they changed the front frame horns slightly, so make sure you have the '70's style hooks.
    The hooks, if I remember,
    are supposed to mount angle down, so the holes you want are the slot and the top most
    rearward hole...if I remember....
    This is a '73 frame...should be the same as your '75
