Failed emission, c02 at idle 25% to high
Discussion in 'The Garage' started by Rolled, Dec 8, 2005.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I need some suggestions on where to start to fix this.
    1982 K20
    350
    465
    m code heavy emissions
    no cat, egr, or canistor from factory
    Here are the results of the test -
    ------------HC ppm--------------C02%
    ------------Limit-----Reading-----Limit-----Reading
    1000 rpm---1000-----141---------2.00-----2.48<----Fail
    2500 rpm---1000-----63----------2.00-----1.58
    Where would you start to fix this? My guess is to rebuild the carb and adjust it as good as I can.
    The motor runs very well and appears to be good enough to pass. It was a mess when I bought it but I got it running very well and I am pretty sure the internals are *good enough*
    I just need this to pass before I put a emission illegal motor in ;)
    Anyways, any advice before I start throwing money at it?
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I just went through the same thing. Put some acetone [see actone thread] in the tank, 2.5OZ per 10gal. Adjust carb with vacuum gauge for highest vacuum, put in new air filter and I passed.:D
    But here is a good diagnostic page.
    http://www.recarbco.com/technical/smog/smoginfo.html
    PS. I still have those transmission parts for you. Did you ever do anything with that 305? Email me and I'll get 'em to ya.
  3. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    you could also put 2 bottles of rubbing alcohol in at 1/8 tank itll pass with flying colors without a 5 gas analyzer its hard to tune perfectly for emmisions
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Turn the idle speed up to 800 or so and try again. That will clean up your idle numbers...
    Rene
