Failed Emissions, Any suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lazydog, Mar 14, 2003.
  1. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    This is the first time I failed emission since I installed the Cater AFB. I wouldn't worry about it to much except I failed kinda bad. Heres how it did:
    Idle_________________Loaded
    HC 142 (350) Pass_________687 (350) fail
    CO 3.99( 3.00) fail_______5.38 (4.00) fail
    The numbers in the parenthesis is what I have to meet. Any suggestions? Thanks
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    New plugs and retard your timing to 4* and you'll be good to go.
  3. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Oh thats right, I set it to 12-16 deg. I bet thats it. I'll go check it now
  4. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    I set the timing back. It seems to hesitate a little when I give it gas off idle. I want to make sure everyting is right so I pass on the retest, otherwise I will have to pay again.
  5. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Try a few bottles of dry gas and a 1/4 tank of super. That always worked for my carbed cars.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Good. That's what they want. If it runs like shi* from overly-retarded timing, it'll probably pass emissions great.
    I can make anything pass a sniffer by retarding the timing (even without cats, smog pump, EGR). It's the visual inspection in some states that's impossible to fake.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm glad I've never had to deal with that crap. I've never had to have a Emissions test on any vechile I've ever owned.
  8. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Run 91 octane or higher, pour a bit of tranny fluid down the carb as someone keeps it running, the detergents clean everything out. And get it really hot before you take it in - like a freeway drive. Worked for me everytime. /forums/images/graemlins/truck.gif
  9. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Hello all, well I readjusted the timing and only failed the CO's Loaded standard. It was 3.51, supposed to be 3.00. I'm still a little pissed since I've never had this much trouble before. I used to have a Quadrajet that never passed the first time. When I installed the Carter a couple years ago it passed with flying colors. Maybe its time for a rebuild? How often do carters need rebuild? I know thats a "depends on the situation" kind of question. Thanks.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Did you change your spark plugs?
  11. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Yeah I did. I actually did it before the first emissions test. A friend of Mine told me of this fuel addative that is guaranteed to pass emissions tests. You add it to a full tank of gas and drive it until its empty then refill and take the test. Has anyone tried this stuff before?
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    a) do a tune up
    b) make sure your engine is good and warmed up before the test, get there right when they open so ur engine doesnt cool off while you wait in line.
    c) use low octane gas, burns more completely
    d) try some of that "you WILL pass emmisions" gas additive.
    j
  13. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    don't know i never tried it but mabe some one heard of putting alittle alcohol in the gas to make it burn clean. Like i said i never tried it though.
  14. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Last time I went threw emissions I was told to put some rubbing alcohol in the gas tank. I put in 2 bottles on 1/2 tank. I also ran my truck on the highway about 10 miles in direct drive to keep the RPM up to heat up my cats. I sat in line at the emissions place for awhile. When I was next up in line I sat there with my engine pushing 2500-3500 RPM in neutral to get some heat back in the cats. I passed with no problems. I was also running my timing at 4* BTDC or even less advance.
