Failed Emissions....help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, May 14, 2003.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    here is the low down. failed last year took it to my mechanic, he hooked it up to his sniffer adjusted some things so it would pass, i went through for my 2nd time and passed came back to him and he adjusted back to run good.(i don't know much about carbs so thats why i paid) Now knowing that and not wanting to pay 60 bux this year here is what i did, i bumped the idle to about 800-900 ran the tank really low and added 2 bottles of rubbing alcohol and 91 gas to about half tank. passed loaded but failed the idle. did bumping the idle hurt me cause thats all i failed on?? its a 78 k10 edelbrock carb with true duals thanks guys!!
    here is the test results let me know if the scan is to hard to read and ill re scan it /forums/images/graemlins/thumb.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Did you get your cat good and hot before the test? Also, bumping the idle up usually helps pass the test. I don't remember the exact reason why, but it does.
  3. Impex
    469
    Chandler, AZ
    hossbaby50: i don't have to worry about cats i dont have them /forums/images/graemlins/laugh.gif
    also wanted to add that i did a tune up not the long ago, so most of that should be good.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Where is your timing set? You might retard the timing some to help on the next test.
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my uncle did somthing to our 78' chevy K10 4x4 that made it pass, he adjust the carb some, probly leaned it out a bit and bumpped up the idle, then when the test is all done adjust it all back to where it was so you get your power back /forums/images/graemlins/smile.gif.
    also they say to run low octane gas, and might wanna try some emmission pass stuff like berrymans that they sell at autozone or carquest might sell somthin. good luck , i hope i dont have to deal with this on my 87.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Lowest octane gas helps it pass, it burns easier.
  7. MOTORHEAD
    MOTORHEAD Registered Member
    Jan 25, 2002
    27
    Northern Va. USA
    Check your timing as well. retard it a tad and see what happens. Have you ever replaced the cat? If not you might want to check into a new one (summit, around $100 for a Catco high flow). Is it a stock Q-jet carb you're running? I'm not sure if you can change the jets on smog-carbs but that might be something you might want to look into, knock it down a jet size if you can. I found a good tune-up, new plugs and reset the timing, change the oil really help me out. How many miles on the engine?
  8. MOTORHEAD
    Jan 25, 2002
    27
    Northern Va. USA
    Sorry just saw you stated you have a edelbrock carb. check out the jets your running in that thing and kick it down a size or two. This will lean it out for inspection and then change it back.
