Failed #%$@$ emissions!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Oct 14, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Finally got the /forums/images/graemlins/k5.gif running and drivable... Passed the visual inspection with the state guy no prob.!! Took it to get sniffer done..big friggin fail!! CO at idle read zero..at 2500rpm was reading over 4!! Max is 1.5. Guessing I'm runnin rich. Need your guys comments if I'm on the right track to fix it.
    Thinkin I should run hotter plugs, rejet the Q-jet, and do something with timing. Where I'm sitting now: Timing is 4' BTDC as per Mitchell spec. manual, plugs R44T (I think), jets and rods I haven't checked yet (was too busy crying in the corner in the garage) /forums/images/graemlins/frown.gif I rebuilt the carb, put new intake on, and it has brand new cats. on true duals. The mixture screws on the front are only turned out from seat a quarter turn. Also driveablity sucks!! Dang thing acts like it has no power... When I get in it the secandaries just bog and the truck don't go nowhere. /forums/images/graemlins/1zhelp.gif
    Thanks in advance, Sam /forums/images/graemlins/usaflag.gif
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    move to a state that doesn't have emissions- VT's cool, just turn on your lights, honk your horn, and head back out with a new sticker. Or, if your like me and over height, no parking brake, and no horn- just pay an extra $10 to the guy at the station, and don't bother doing anything other than putting on a new sticker.
    sounds to me like your timing is off- mine was running bout the same as you- did complete tune up, plugs, wires, cap, rotor etc... ran about 75% better, fixed the timing- runs 100% better.
    Brandy
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'd think timing should be bearer to 8-10 BTDC. Bump it up a bit and see if it pings under load. I set my timing by ear, keep advancing until it pings under a light load and then back it off a hair.
    Rene
  4. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    Here is a simple and cheap solution.... rubbing alcohol. Top off your tank with the highest octane gas from the local station then pour a bottle into the tank. Drive it to the emissions tester and collect your passing cert. /forums/images/graemlins/deal.gif
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Hmmm...I thought the magic potion for passing emissions was low octane gas. The idea being that the stuff burns so fast that the combustion is more complete. That bottle sold with a guarantee to pass says only to drive right to the emissions check with it and drive very lightly. I always thought it was to avoid pinging from the low octane.
    This could start a whole discussion over again, though.
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you have problems that can't seem to be solved email me and you can use my address out here in Lincoln County. I live by Limon, Colorado, we have no emmission testing out here. Your insurance will drop like a banshee too...
    John
