failed inspection today (HELP NEEDED)
Discussion in 'The Garage' started by wraenking, Oct 31, 2006.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, i figured i was going to fail , but i needed the rejection sticker to get me another 44 days
    list of failures
    1. tires stick out = buying bushwackers today
    2. rear brakes not working enough? 14 bolt disc conversion with new prop valve thats supposed to automatically send the right amount to the rear from inline tube. = solution?
    3. e brake not holding enough = re adjust them, should be fine
    4. emissoins
    HC = standard-152 Me: 278
    CO = standard-1.36 Me: 2.80
    now, paul (ryoken) is gonna talk with me tonight to see what we can do, but ithe more input the better
    Rootbreaker, i am running the hooley truck aveneger, so i know it can pass emissions, but i need to know how you did it
    thanks everyone
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Move out of state.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Get the Disc/Disc propvalve from inline tube. I have one and it works great, my K5 stops better than my moms 2000 Suburban.
  4. goldwing2000
    goldwing2000 Guest
    Link?
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i have their prop valve. i did have an adjustable that i sold, but they said i wouldnt need it. so im not even sure how to adjust so the rears are breaking better. unlees its part of when i adjust the levers for the ebrake
  6. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    your gonna need a bigger master cylinder to push more fluid, not a proportioning valve. that does nothing except limit the amout of fluid going to the rear. i finally got mine working correctly.
  7. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    which one did you go with? ill try to get one at napa
  8. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    1-TON MASTER CYLINDER- Part # 101534 - from ADVANCE AUTO $20. it's a remanufactured one but has a bigger bore diameter.
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    and this WILL solve the problem you think? i mean, stop on a dime as it is now, i guess im just usinf more front than rear.
    i guess ill have to re read the whole bench bleading thing lol
  10. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    it solved my problem. i have d60 front with 14bff rear with disk brakes. i replumbed the rear lines directly off of the master cylinder. i eliminated the factory prop. valve. i did that before i put in the different master cylinder tho and it could possibly work with the new master cylinder. with the stock m-cyl. i could not lock up the rear brakes with it on jack stands. now they work great.
    an aftermarket prop. valve only limits the fluid going to the rear if you have too much braking power. if you don't have enough to start with, how is going to add any??
  11. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    that makes sense. i hope i dont have to run new lines. i will pick up that 1 ton tonight. and the quality is ok?
  12. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    quality of what, the master cylinder? mine was fine, but you know how remanufactered parts can be.
    you wouldn't have to run new lines, just eliminate the stock valve. you might not even have to do that tho. you can buy the adaptors to put the lines together.
