Failed My Emission
Discussion in '1982-Present GM Diesel' started by BurbLover, Apr 16, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Well, I got my K5 emissions tested on Thur & it barely failed. The mechanic recommended I replace the fuel fliter assembly as it's leaking out fuel & in air. Also recommeded I clean ou the crank case pressure thingy and replace the return lines as they are all leaking fuel out and air in as well. The injectors are also leaking, but that won't affect emissions, so due to expense, they'll have to keep leaking for now. Well, maybe I can get everything fixed this weekend and retest on Monday.
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    That sucks...might consider getting the injectors rebuilt at the least. I got mine done through Accurate diesel (www.accuratediesel.com) and the price was very reasonable and the turn around time was quick.
    My injectors leaked too, plus I think they were 'cracking' at way too low a pressure and not spraying a fine mist anymore.
    Rene
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Fill it up with biodiesel. Cuts your emissions significantly. Make sure you air filter is clean/new.
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    What's biodiesel & how do I use it. Also, where could I get this. I will put a new filter on as well. Plan on doing this stuff tomorrow so I can retest on Monday.
  5. azblazor
    May 5, 2001
    1,953
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Bummer Mark.... Better luck Monday....
    Hey, can't seem to get ahold of that guy with the engine.... I will keep trying.
    John
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks for the site info Rene. I replaced the return lines, the filter & modual, and cleaned it up a bit. Leak that was comiong from the filter area appears to be gone. This was biggest concern before. Gonna try on Monday for emissions. Wish me luck!! Also, I wish I looked at the site before I bought the return line stuff. Kit through Napa was 70-ish and a make-up kit through Chevy (lines) were 9 apiece (need 8) plus two caps. Kit through the Accurate Diesel was only 22. Also, there injector set is 190. Not too bad. If I fail this time, I may just park it until I can afford the injectors. Otherwise, I'll either sell it or parts it out.
  8. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Actually...injectors for your truck would be 148. the short injectors are 190.
    Good luck with the re-test!
    Rene
  9. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    BTW, is there supposed to be a cat on my exhaust system? I just looked under today and there is dual exhaust from the manifold, but only mufflers, no cat. Just wondering.
  10. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    No factory cat that I'm aware of...AFAIK they got straight duals from the factory.
    Rene
  11. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks. Since I just put one on my wife's Burb for almost $300, I was hoping I didn't need to buy two more /forums/images/graemlins/laugh.gif
  12. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    WOOOOHOOOOO!!! I passed, barely, but I passed. Max is 40% opacity. I got 36%. This gives me a year to replace my injectors and get the fuel system flushed out. Might also flush the oil system due to how bad it was when I changed it.
    Now, time to install lift, 1-ton axles, SM465/205.... /forums/images/graemlins/whistling.gif
  13. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    The oil will always look like that...it's a 6.2 trademark /forums/images/graemlins/crazy.gif
    Congrats on the pass! /forums/images/graemlins/waytogo.gif
    Rene
  14. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    The oil will always look like that...it's a <font color="red">Diesel</font> trademark
