Fall Clean-up - Parts For Sale
Discussion in 'General Parts for Sale' started by nomadman, Oct 13, 2004.
  1. nomadman
    nomadman 1/2 ton status
    Oct 6, 2004
    168
    Enfield, Ct
    4X4 K5 Stuff
    Gas tank (replacement) for carb motor, w/ filler, no sending unit - $20
    Crossmember w/ skidplate from ’86 w/ NP208 - $20
    Skidplate from ’86 w/ NP208 – no crossmenber - $10
    NP 208 T/C w/ new chain - $150
    T/C to trans brace - $10
    Turbo 700R4 w/ adapter for NP208 – needs rebuild - $75
    Motor mount cups w/ braces to bellhousing cover - $15
    Cast aluminum bellhousing cover - $20
    Pair 10 bolt axles from ’87 K5 (28spline) I need to check ratio- $150
    Pair 10 bolt axles from ’90 K5 (30spline) I need to check ratio - $250
    OEM aluminum 8 hole wheels (2) sets both need refinishing - $75 set
    4WD PS box & pump (2) available, one needs seals - $50/$100
    Fan shroud (2 piece) complete - $15
    Fan shroud (2 piece) upper half only - $5
    Seat belt retractors, blue - $20
    Sliding tinted windows for F/G hardtop - $50
    Power brake booster w/ master cylinder and proportioning valve (2) available - $25
    Custom made softtop w/ F/G bows. Snaps need to be screwed to 1/4 panels, roof and tailgate. Vinyl got somewhat stretched out of shape from ice sitting on it during last winter. No reasonable offer refused.
    2X4 Pickup stuff
    2WD PS box & pump – good for X-over conversion - $75
    Gas tank (replacement) for carb motor w/ filler & sending unit - $40
    Turbo 350 longshaft w/ TC – strong shifts - $100
    Front 2x4 leaf spring mounts – good for 4x4 shackle flip - $30/pr
    P255x70-15 all season tires on 5 lug Chevy truck rally rims – no caps/rings, exc. cond. - $175
    Fan shroud (2 piece) complete (shorter radiator than K5) - $15
    Rear springs, 4 leaf - $40
    Class III receiver sold by U-Haul only 6 months old - $50
    Generic Chevy truck stuff
    Tilt column complete - $75
    A/C system missing compressor and condenser - $100
    TBI system from 350 needs only distributor and coil - $250
    Edelbrock Permformer aluminum 4 bbl intake (3) available, glass bead blasted - $100 ea
    Edelbrock carburetor (2) available – $150 ea
    HEI distributor (2) available, vac adv - $50, elec adv - $50
    Rear bumper (2) available – 1 w/ trim, 1 w/o trim - $20 ea
    Front bumperettes - $20
    Dash cluster from an ’86 all gages work - $15
    SS mirrors - $20/pr
    Dash pad, grey, some cracks but seen worse - $15
    Hoods (1) no dents/rust - $40, (1) no rust, minor dents - $free
    Core supports – (1) single head light, (1) double, surf. rust only $30 ea
    I will ship anything anywhere at your expense, local pickup always welcome. Prices are negotiable within reason. Trades considered. Thanks for looking. /forums/images/graemlins/usaflag.gif
  2. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    Hmmm, no response, it can't be my breath ........... prices too high or ????
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    what part number are the edelbrock intakes? do they have EGR?
  4. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    Two of them are 2101, Performer, and the other is a 7101, Performer RPM. None of them have EGR capability. Thanks.
  5. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    I realize I am new to ColoradoK5.com but my reputation can be viewed on eBay; user name = nomadman2001.
  6. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    lots of nice and interesting stuff, its just a tuff market on here sometimes...not always the demand you might think... /forums/images/graemlins/dunno.gif
  8. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    Thanks for the plug. I have realized the $$ might be high so if someone is interested I will consider offers .
    I am trying to save for some new sneakers for my K5. I am leaning towards Firestone Destinations, 33x12.5's. They have a pretty good review on the TireRack.com . I plan to use this for a winter vehicle and weekend offroader.
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I want some of the stuff (like the NP208) but I suspect shipping would pillage the deal. I'm willing to bet other people are in the same boat.
  10. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    Fed Ex .com shows $38 if you had a non residential address, assuming the post for weights is close; "78 pounds in a well packed box". I would go $125 on it if that helps.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    How much to my door?
  12. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    I will have to work on that. Fed Ex will not deliver over 70 lbs to a residential address. Is there a Forward Air terminal anywhere near you? They are very reasonable from my past experiences.
  13. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
    No, I guess not. Just checked and the closest seems to be in Romulus, 10 + hours away. I will see @ UPS.
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Probably not within a hundred miles. Usually any freight that comes into my area (upper peninsula of michigan) is transferred to a company called "UP Special Delivery".
    I'll see if I can find a business to have it delivered to.
  15. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    No luck yet on having stuff delivered to a business.
