Fan bolt patten 6.5L same as 5.7?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rx7gslse, Nov 7, 2006.
  1. rx7gslse
    rx7gslse 1/2 ton status
    Nov 4, 2002
    362
    DFW, TX/Mexico
    ok, here's my question... In a continued quest to keep my truck cool and my a/c cranking... Do the 4 bolts holding the fan clutch to the water pump on an 89 350 (serpantine setup) match the 4 bolts for the sam eyear 6.5L TD fan clutch?
    Reason being.. wondering if these Duramax fan adaptors meant for a 6.5L will work on mine...
    http://www.ssdieselsupply.com/category_3_Cooling_Fan_Upgrade_Kits.html
    not the cheapest solution.. but cheaper than a higher voltage alternator and proper aux elec fan setup.
    TIA!
    Eric
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I'm not sure of the bolt pattern but I do know the diesel fan clutch is different than a gasser. I can't tell ya what the difference is either:o
    Contact SSDiesel Supply, they are friendly and will be able to tell you the differences.
  3. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    the boltpattern is the same. i've heard of guys using the dmax fan on the 6.5.
  4. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Read it again. He doesn't want to put a Duramax Fan on a 6.5:doah:That's what his link is all about. He wants to put a Duramax Fan on a SBC 350!:D
  5. k204dr
    Aug 27, 2004
    463
    TN
    missed that part. the smallblock has the same pattern also though.
  6. rx7gslse
    Nov 4, 2002
    362
    DFW, TX/Mexico
    got some parts in today to make this work..
    FYI, the bolt pattern to mount a fan clutch to teh water pump for a 6.5L TD is about 2.25" whereas the bolt circle for the SBC is just a hair under 2"
    FYI, TDs use a 3/4" pilot hole on the fan clutch vs the SBC 5/8" hole. Got some more work ahead of me still to make this work.... ;)
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I just installed a Taurus fan on my TJ a few weekends ago. If you wire it up correctly, there is no need for a high amp alternator at all. The relays do all the work as far as power supply to the fan. All you need is a signal from a toggle switch, temperature switch, or ignition switch of less than 5 amps. The signal will energize the coil in the relay(s) & pump the 30-60 amps of power to the fan motor. Here is a nice write-up for you.
    And a few others
    http://www.creeperjeepers.org/Electric%20fan%20install%20in%20a%202.5L%20TJ.html
    http://www.pirate4x4.com/tech/taurus/index.html
    http://www.fordmuscle.com/archives/2003/02/electricfan/index.php
    http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3420588&Main=3406107
    http://www.greatlakes4x4.com/showthread.php?goto=lastpost&t=45442
    HTH,
    Buddy
    Edit - forgot to mention that the whole setup cost me under 100.00 total.
  8. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Buddy,
    You are talking about an electric fan and his questions are about a water pump mounted fan.:D
  9. BUDDY
    Apr 28, 2000
    744
    Midland, TX
    I know. :doah: Maybe I should've made it clear that the electric fan can be done correctly for less than what he's wanting to do.
    Anyways,
    Buddy
  10. rx7gslse
    Nov 4, 2002
    362
    DFW, TX/Mexico
    possible to do yes... but most of those don't really pull that many CFMs.. and I need *more* CFM :)
    It could be done with an aux fan, but I spend a lot of time idling waiting at customs, and the voltage barely keeps up with both a/c running, so an extra 30amp fan ain't gonna cut it..
    Anyway, I finished up my mechanical fan setup today and it ROCKS!
    Basic summary... Duramax fan from GMparts direct (like $40, but took d@mn near a month to get here...)
    'Modified' fan clutch off a 96-98 6.5L diesel. They use the bolt on setup like ours rather than the thread of of the later trucks, but the bolt pattern is different to mount to the water pump..
    Ended up getting new holes drilled to match the 1.93" bolt circle for our water pumps, as well as a reducer bearing to ensure that the pilot hole was still perfectly centered..
    Anyway, got it all put together today, trimmed the fan shroud for clearance (wound up hitting down by the lower radiator hose, so it required some cuttin)
    All seems to work well and good cruisin around today... I'll give it the real test tomorrow on my trip back in from Mexico (sitting for 15-45 minutes in traffic in 100+ weather does not keep a suburban happy)
    So yeah.. That's how I got it to work.. Conventional? nope.. Functional? certainly :) All for about $200. (50 fan, $135 fan clutch, $15 misc bearings bolts etc..)
  11. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    DFW to Mexico. That's some commute! What do you do South of the border?:D
  12. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    In a suburban? Do you really have to ask? J/K
    Jimbo
  13. rx7gslse
    Nov 4, 2002
    362
    DFW, TX/Mexico
    heh... I actually live in WAY South TX pretty mcuh full time now.. My daily commute into Mexico is only about 30miles... But MAN do the roads suck. Just this morning I think I got airborn.. They put up a new 2' tall speedhump on a blind corner. WHEEE! Life is good.. especially in Sept time when the entire city floods once a week....
    For work? I work for a US manufacturing firm.. I'm on 'assignment' for awhile to start up a group down here. We make fiber optic equip for high speed networks, mostly telecom stuff....
    Man, I have some stories.. that's for sure...
