Fan controls.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jul 5, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    [​IMG] I have replaced the freaking fan motor, I've replaced the freaking fan switch in the dash control unit.
    And the damn thing still wont work on high, adn even at the other settings it just cuts off then I flip on low and then back to medium and it starts working again, only to shut off again in 5 minutes[​IMG][​IMG]
    WTF? What else is there to replace?
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I dunno if this is yer problem but my ground wire going to the fan motor was quite corroded. My fan would work occasionally[​IMG] and it drove me nuts for quite a while till I cleaned and tightened the ground wire...
    Rene
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    When I replaced the motor I made sure all the contacts were squared away.
    I seem to remember something about a resistor. But Im not sure what it looks like or where it is.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    This was on an s-10, but my blower motor had gone out. The new one came with a metal "hamster wheel". I then had problems with it not going into high. I replaced the switch, the relay, everything! Then I found out that the metal wheel was causeing too much resistance cause it was heavier than the plastic one the original had. I found an original plastic one and put it on and it worked fine after that. I dunno if that helps or not [​IMG].
    I've got a mind like a . . . a . . . what's that thing called?
    <A target="_blank" HREF=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</A>
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes, that is what I was goign to suggest, the resistor.. It should be somewhere close by the fan motor if I am not mistaken. This contorls the juice going to the fan fromt he switch.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  6. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    all good queses but it is the high speed blower relay,a little metal box,all G.M. products use this setup,the resistor is fer lower speeds ,high speed uses straight 12 volts for high speed! hope this is it. ithis relay is under hood the large purple wire from b.m. goes to it.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, on the lower speeds, the fan blower relay routes power through the various resistors to regulate blower speed. When you switch to Hi, then the relay switches so that power to the blower is coming straight from the battery. Trace the wire from the blower motor and it will take you straight to the relay mounted on the firewall or a/c box.
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
