Fan distance from radiator
Discussion in 'The Garage' started by big pappa b, Nov 23, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Looking for opinions here. Since I put the big block in my /forums/images/graemlins/k5.gif my fan is roughly 5-6" (closer to 6) from the radiator. The radiator is a 3 core but I'm getting a new 4 core this week. I already have a 2" spacer but I still need to get a fan shroud too. With the current setup it runs about 195 with a 190 thermostat..might get up to 200 just sitting. I know the 4 core will put it about an inch closer to the fan and I'm pretty sure the fan shroud will help a lot too..if I can find one.
    Thought??
    What's your spacing from the rad?
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    When I put my big block in my full size, I had the same experience. The factory big block shrouds are a couple of inches shorter (mostly in the lip around the fan). Right now my fan is only about 2 inches from the radiator and it works better then ever.
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    OK...so how did you get it closer?? and what shroud are you using?
  4. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I have a factory clutch fan. I moved the core support when I put the S-Blazer body on the fullsize frame.
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Are the small block shrouds bigger?? Deeper??
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get yourself an electric fan for aux. cooling and forget about it. I doubt you could ever make it over heat with both.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I don't think distance matters as long as it is shrouded correctly. The factory shroud on my truck is probably 15" deep because the engine sits so far back against the firewall.
    I would suggest getting the deepest shroud you can and then maybe going with fan clutch. They are alot deeper than the spacers. You can always fab up an extension to bring the shroud around the fan. Have you ever seen shroud on a 3rd Gen Camaro with V6? Those shrouds are way deep. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
