fan hitting the cowl???
Discussion in 'The Garage' started by pismorat, Nov 9, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    When I first got my truck, the frame was cracked around the right engine mount, the fan used to hit the cowl, I welded it up and has been fine for 4 years. Now it is starting to do it again (mostly when turning right and on the gas), but the frame is in great shape still, any comments?? /forums/images/graemlins/confused.gif /forums/images/graemlins/truck.gif
  2. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Torn motor mount insert or broken/loose mounts for fan shround? Maybe a loose or broken body mount under your front clip? Just shooting from the hip here...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    bad engine mount?
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    If your body mounts are shot it would not only lower the body down toward the fan but could also let it flex more(like when turning) alowing the fan to get inot the cowl. /forums/images/graemlins/thinking.gif
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I say mounts as well and replace the tranny /Tcase mounts while your at it, go with poly mounts.... /forums/images/graemlins/deal.gif
  6. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I'm not trying to be an A$$hat, but the COWL is located above the hood and back by the wiper arms... The SHROUD is located around the fan and directs air to be sucked through the radiator.... Therefor, If your fan is hitting the "COWL" You have more serious problems than a cracked frame or mount.... /forums/images/graemlins/deal.gif
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I read hte topic and was trying to envision the fan hitting the cowl and all I saw was total carnage where you wouldn't worry about that
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    we knew what he meant asshat... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. romanviii
    romanviii Registered Member
    Oct 31, 2003
    13
    California
    I wouldn't rule out bent fan blades in addition to all thats been said also.
  10. Batmanjr
    Mar 23, 2001
    1,537
    THanks Fumes! /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rolleyes.gif
