fan relay problems
Discussion in 'The Garage' started by 90BCk5, Oct 24, 2006.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    ok so heres the deal, ive got two taurus fans (pullers) rigged up on my blazer and wired up using a painless thermostat/relay kit for chev small block. now the instructions say that i can run 1 or two fans as long as the combined amp draw for both is not over 30amps. now my problem is that when i hooked everything up and fired them up all was fine. now i cant get the bastards to work.
    does anyone know what the amp draw on 2 ford taurus fans is???
    i've checked all my other connections, my batteries are both charged, connections tight..... is it possible ive cooked my 30amp relay:doah: and need a
    mo' bigga one??
    thanks
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i would run 2 relays, if you are goign to run 2 fans
    if they arent working at all now, check your fuses, might have blown somtheing
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I'd bet they're pulling at least 15 each... You more than likely popped the fuse powering the relay...
    You can check your amp draw by taking the power lead for the fan attach it to a multimeter, put the other meter lead to the positive battery post, with your meter set to amps... It'll run, showing amps drawn.. Just check max amp on your meter, alot are only 10 amp...
    But I definitely would be running 2 relays...
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i believe a single taurus fan will draw 31 amps on high.
    i put 1 in a s10 blazer with a 350 useing a 30 amp relay for low and a 45 amp relay for high.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    They are probably not going to pull 30amps.
    They are probably somewhere around 6-8/piece. On a hot day with undersize wiring, mabey 10-12amps at startup (elect. motors take alot to 'startup')
    I would say your fine on a 30amp relay. That's what mine setup is. Bump to a 40amp relay (and at least 12ga wireing, which I think the painless kit is already) if your worried about it.
    But your relay could be bad.What brand is it? Alot of the cheapy auto store relays are really crap.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Not a chance.
    Stuff rarly pulls what it's "rated" for. You need to look at things like duty cycle, startup draw..and more.
    Most vehicles today come with 70-90amp alternators. Until the 90's, 60 was the norm, 40 wasn't uncommon. My '73 came with a 37amp alternator. That's for the whole vehicle, if you have 1 accessory taking 30amps all the time, you'd be in a world of hurt, electrically speaking.
    Flex-a-lites biggest dual setup draws 28amps max,according to their specifications. Avgs about 20, they say. So that's 10/piece, for 2 15" fans.
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I should go downstairs and do this.. Got a shop battery, my meter and a 2 spd Taurus fan sitting around...
    Most aftermarkets have continuous ratings of 8 to 12, I've heard the Ford draws more.. Mid to high teens, depending on wiring..
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    SO go on, what are you waiting for? I got a beer I can send you....:D
    You got a good meter, right? Most 'regular' meters only can measure up to 10amps.
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    you have a tauraus or the windstar i gave you?
    fan slut lol
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Or better yet, go with what the electrical engineer did for the Tarus.
    That is, pop the hood of a Tarus and see what fuse/relay they use.
    Who's got a Taurus in their driveway???????????????????????????????????
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    My aching knees are afraid of the stairs... :o :haha:
    Actually I just remembered I brought my meter back to work.... It does 25 amps iirc..
    You may very well be right... This is just internet hearsay, I'm reporting.. I'm guessing it's at least 10....
    I've also heard the ones out of Lincolns are better...
  12. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    sounds good, ill go try testing my fans, that is if i can find my voltmeter after moving:confused:....
    so yeah, who's got a taurus in their driveway anyhow???
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    this is what i was told after we kept blowing 30 amp relays for the HI side of the fan. went to a 45 amp relay and the problem went away. :dunno:
  14. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    oh, and the relay is whatever came with the kit. i was just looking for it on their site but cant find my kit...
  15. dyeager535
    26,980
    Ouch.
    http://www.fordmuscle.com/archives/2003/02/electricfan/index.php
    I can't vouch for their testing methods, it sounds like that fan draws WAY too much on startup, but there are some numbers. Just looked at those and "Taurus" in the article, so no idea what else it says. :)
  16. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Well, I stand corrected. My humble apologies.
    That said, that's just insane!, not to mention just stupid. No wonder Ford is going bankrupt. That article also says the fan pulls 2000cfm. Not sure how they tested that. By comparison, Flex-a-lites fan, at 8-12amps, pulls 2750cfm. More amps doesn't nessisarly make a more CFM, it could just be a cheap low quality china motor. Who knows...
    40amps...I still have a hard time believing it. I'd still like to see what fuse and relay is under the hood of the Taurus.
    So, in order to wire 2 of these fans, based from that information, you'll need 7ga wire, which isn't normally made, so 6ga battery cable, an 80amp maxifuse, and an 80amp relay at bare minimum. Seems a little extreme.
  17. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    This is from my Electrical engineering buddy, who works for an OEM.
    What's the diameter of the fan?
  18. dyeager535
    26,980
    The dual fan setups GM used were not designed to both come on at the same time, with that sort of draw, it's no wonder.
    Yet another reason not to run both fans at once, all the time, or use high all the time when a multi-speed fan is used.
  19. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    sorry man, theyre 12 inch diameter fans
