fan shroud
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80blazer, Jun 8, 2001.
  1. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    Help my 80 Blazer is without a fan shroud and its getting REALLY hot here in Phoenix. Every thing is new and in traffic the temp. climbs to 230 plus does any body know where I can get a shroud that fits 19in radiator new or used. Thanks All Jeff
    Its time to lock them in!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Try 40th street auto wrecking, or there's another good one out in Maricopa, but I can't remember the name of it.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  3. 80blazer
    Mar 4, 2001
    41
    glendale arizona
    Thanx Pugsley I will give them a try. Jeff
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've gotten several parts from both, and was treated really good, with good prices too. Good luck!
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Summit racing sells universal shrouds.-They're chrome- They have a picture of one on their website. About $40.
    I used to live in Phoenix. 9 St and Bell before we moved to a crappy little town called Memphis TN. I went to GCC.
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  6. Grim-Reaper
    7,385
    Atlanta
    You might also try a differnet Thermostat. Sometimes a 180 stat lets the coolant move too fast and it doesn't have a chance to sheed heat in the radiator. It sounds backwards but a 195 stat you may run cooler.
    I helped a bud with a SB400 that he could not keep cool. finnaly we tossed a 195 in it and the problem went away (this was long ago but many sources since then confirm this).
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
