Fan shroud...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Jul 18, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Anybody know a good source for fan shrouds? (cheap) Wondering which one I should get... Radiator is original to the truck which was a diesel. 400 going in this week. Which one should I look for, diesel or 350? 400 not listed in LMC for my year truck(obvious reasons). Diesel also not listed.... I'm thinking diesel but not sure if 3 blade, 400sbc, clutch fan will work with it. What do you guys think?
    Thanks, Sam /forums/images/icons/cool.gif
  2. dyeager535
    26,982
    191
    You can still buy the 2 piece ones from GM, so if you can't find good ones locally, you might want to go this route. It will be more expensive, but the used ones are typically pretty brittle, and it doesn't take much to break them. IIRC, my friend told me it was either $20 or $40 for one half from GM, but if you can get the part number, gmpartsdirect.com might be able to beat that.
    Not really sure on the 400/6.2 issue though on fan shroud size, the diesel radiator is thicker, but the 400 is the "same size" as a 350, so I've no clue.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Try LMC.. They have the stock shroud.
  4. seslick77
    Jan 27, 2002
    220
    LMC is the only place I've looked... It had a 2 piece before. Busted into little pieces when I took it off. Guess I'll try dealer for part numbers and go from there... /forums/images/icons/tongue.gif
