FAQ library dream
Discussion in 'The Lounge' started by Ddragggon, Mar 23, 2003.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    allright, as some of you saw in the `Off Topic Forum' I'm currently working on building a tech library/crossreference index that'll hopefully help cut down on the sheer number of duplicate and triplicate posts, by providing a fast link to the answers. as an example, 33 inch tires on stock suspension has been asked probably 400 or so times in the last couple weeks, even tho there's a Tire fittament table on the site that gives a pretty good idea of what'll fit what, and what kind of fender hacking needs to be done.
    at anyrate, here's the basic index thus far, with a few hot topics that've been requested added to it. I'm trying to work out some details with Steve on what to include, and what not to include in it, as well as what formatt he wants it in.
    the goal with this thing is to start with the rudimentry index with links to posts that contain the information. the next phase is to create writeups, and tech files on all the pertinent information, and possibly move it off the forums, and onto its own HTML pages. we'll see what happens. at anyrate, here it is:
    The index at this point:
    <font color="White">Version 0.0.3</font>
    Body
    -Sheetmetal
    --Rust repair
    ---Tailgate Hinge
    ---rusty floor removal
    --Hood
    -<font color="Red">Paint
    --general tips
    --Truckbed liner</font>
    -Toppers
    --Storage Ideas
    -doors
    -Tailgates
    Frame/suspension
    -leafsprings (Spring Rate Table)
    --Shackle Flips
    ---Homemade Shackle flip
    -IFS
    -body mounts
    -Roll Cages
    -<font color="Red">Frame Cracks</font>
    -Bumpers
    --Home made
    --professional built
    <font color="red">-Shocks</font>
    Glass
    -Windshields
    -movable windows
    --Mechanical regulator
    --electric regulator
    --<font color="Red">Tailgate window</font>
    -fixed glass
    -rubber surrounds/weather stripping
    Steering
    -Power steering systems
    -2wd
    -4wd
    --conventinal
    --Crossover Steering
    --hydro assist
    --pure hydraulic
    Driveline
    -<font color="Blue">Transmission</font>
    --Automatic
    ---THM350
    ---THM400
    ---200-4r
    ---700-r4 (4l60)
    ---4l60e
    ---4l80e
    --Manual
    ---SM420
    ---SM465
    ---NV4500
    ---NV5600
    -<font color="Blue">Transfer case</font>
    --NP203
    --NP205
    --NP208
    --NP241
    -<font color="blue">Axles</font> (ID Chart)
    --Axle Swaps
    --Front
    ---General
    ----Balljoints
    ----Hubs
    ---D44
    ----Light duty
    ----heavy duty
    ---D60 (Maintenance Manual)
    ----35 spline Upgrade Kit
    ---D70
    ---Corporate 10 bolt ( small ring gear )
    ---Corporate 10 bolt ( large ring gear )
    --Rear
    ---10 bolt
    ---12 bolt
    ---14 bolt FF
    ----Axle shaving
    ---14 bolt SF
    ---D60
    ---D70
    --Traction Control devices
    ---Spider gear welding(14BFF)
    ---ARB airlocker installation
    wheels
    -tires
    --Basic Fittament table
    ---33's on stock suspension
    ---Fender Trimming Tips
    -Rims
    -Beadlocks
    Brakes
    --discs
    --Drums
    --rear disc conversions
    ---12B Atron 10/12B conversion
    ---14BFF(Offsite/2/3)
    --Master brake cylinder
    --<font color="red">Brake lines</font>
    ---Hardlines
    ---<font color="Red">Extended brakelines</font>Here's 1/2/3/
    --Proportioning Valve/2/3
    --Vacuum booster
    --Hydroboost
    --trailer brake control units
    Electrical
    -Engine Electrical
    --Fuseable links
    -dash/cluster electrical
    -cab interior electrical
    --dome lights
    --stereo
    --power doors
    -cab exterior/chasis electrical
    --headlights
    --marker lights/turn signal
    --trailer wireing
    Engine
    -<font color="blue">General</font>
    --<font color="Green">Ignition</font><font color="red">
    ---spark plugs
    ---spark plug wires
    ---Distribultor
    ----Points
    ----HEI
    -----Conversion
    ----Coilpacks</font>
    --<font color="Green">carbureation</font>
    ---dualjet
    ---Quadrajet
    ---Holley
    ---edelbrock
    --<font color="Green">Fuel injection</font>
    ---TBI
    ---TPI/MPI
    --<font color="Green">Emissions</font>
    ---EGR
    ---PCV
    ---AIR
    ---charcoal canisters
    ---catalytic Converter
    --<font color="Green">exhaust
    </font>---manifolds
    ---headers
    ---mufflers
    <font color="Green">--engine systems</font><font color="red">
    ---Oil
    ----Oil additives
    ----oil filters
    ----oil coolers
    ----oil pumps
    ---Cooling
    ----radiator
    ----hoses
    ----heater core
    ----Waterpump
    ---Fuel delivery
    ----fuel pumps
    -----electric
    -----mechanical
    ----fuel filters
    ---air intake
    ----Vacuum
    ----air filters</font>
    --<font color="Green">Forced Induction</font>
    ---turbo
    ---centrifical blower
    ---Roots blower
    ---Vane blower
    -<font color="Blue">I6</font>
    --General
    ---250
    ---292
    -<font color="Blue">V6</font>
    --General
    --old GM
    --twin 6
    --3.2
    --3.8
    --4.3
    -<font color="blue">Cold Fusion</font><font color="Red">
    --plausibility thesis
    --stable reactor designs
    --saftey measures</font>
    -<font color="Blue">V8</font>
    --<font color="Green">SBC</font>
    ---General
    ----Manifolds
    ----Heads
    ----blocks
    ---283
    ---301
    ---304
    ---305
    ---307
    ---327
    ---350
    ---377
    ---383
    ---400
    --<font color="Green">BBC</font>
    ---General
    ----Manifolds
    ----heads
    ----blocks
    ---366
    ---396
    ---427
    ---427T
    ---454
    ---496
    ---502
    --<font color="Green">Cadillac</font>
    ---General
    ---478
    ---500
    ---Northstar
    --<font color="Green">Buick</font>
    ---General
    ---350
    ---400
    ---455
    --<font color="Green">Oldsmobile</font>
    ---General
    ---350
    ---400
    ---455
    --<font color="Green">Pontiac</font>
    ---General
    ---307
    ---350
    ---400
    ---455
    -<font color="Blue">Diesel</font>
    --General
    --6.2 TD
    --6.5 TD
    --Duramax
    --olds 350 diesel
    --cummings TD
    --Powerstroke
    --Caterpiller
    Aftermarket accessories
    -York Compressor Installation
    -aftermarket stereo
    -CB
    -BLing Bling
    --Black Hole Theory/2/3/
    -Winches
    as you can see, I've already linked to the existing tech library where articles already existed, as well as some posts that seem to come up once every other week or so...
    let me know what else I've missed either here, Via PM, or via AIM (Ddragggon)
    anyone who wants to help with this is more then welcome to jump on it, as I am but 1 man, and not as omnipotent as I wish I were.
    -Rich
    The Ddragggon
  2. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    Wow! /forums/images/graemlins/eek.gif That list is amazing!! I think that providing people use it, it should cut down on lots of repeat questions. Good luck!!!! /forums/images/graemlins/thumb.gif
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  4. Ddragggon
    Apr 25, 2001
    2,657
    This topic definately needs to be included.
    33's on stock suspension /forums/images/graemlins/thumb.gif
    [/ QUOTE ]added...
    I plan to flesh the thing out more as I get into it, with more specific stuff, although I do agree: I've not only been hearing that question for the last 5 years since I got my first C20 pickup, I've even asked it when I was still an Ultra Newbie.
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    You might want to think about under "movable windows" putting a subcategory for the tailgate glass.
    Also- under brakes....Extended lines- and also the Combo Valve- (prop valve) those 2 have been hit hard lately- with the same answers coming each time
  6. Ddragggon
    Apr 25, 2001
    2,657
    [/ QUOTE ]Added them. thankyou, ( Also bump for the early morning Monday group)
    -Rich
  7. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    FRAME
    cracks
    the problem i had when i first discoverd CK5 a couple years agao
  8. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Looks great. I had to really think about which common questions come up, that you did not already cover. /forums/images/graemlins/thumb.gif
    Painting tips.
    HEI distributor conversion.
    Homemade bumper plans.
    Which Winch?
    Do it yourself bed liners.
  9. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    How about this..........................If Steve gives it the OK.
    Several members (I would volunteer) do the research,put together the links (of perhaps 5-10 topics), then forward the list to you/Steve for approval. That would make it alot easier on you/Steve. It looks like you have alot of time invested in the "list" /forums/images/graemlins/deal.gif already. Just a thought.
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    i would help too, as much as i could. this is what i think we've been needing for a long time, but now someone has finally taken the time to do it. good job, man! /forums/images/graemlins/thumb.gif
  11. Ddragggon
    Apr 25, 2001
    2,657
    Poster: MOABDADC22
    Subject: Re: FAQ library dream
    [/ QUOTE ]that'd be cool, and I'd deffinately welcome the help. I'm doing this basicaly fully volunteer style (steve said he might give me a membership if he really likes it, but thats not why I'm doing it*) and any help I could get would be great. still working out some stuff with Steve on what to and not to include in this.
    also, the grand master scheme for this crazy index thing is merely in `Phase 1' with the rudimentary index in a post thing going on. eventually, it'd be nice to see it on its own web page, (phase 2) and then start replacing the crosslinks to posts with good solid writeups (Phase 3).
    Poster: 75-K5
    I would help too, as much as i could. this is what i think we've been needing for a long time, but now someone has finally taken the time to do it. good job, man! /forums/images/graemlins/thumb.gif
    [/ QUOTE ]I've thought the same thing for a while... its just my brains are kinda slow and dumb when it comes to taking the idea of `gee it'd be nice if we had one of those things' to `yanno, I bet could sit down and probably bang one out'
    I think the next step with this thing, is to put it in the garage, (with Steve's blessing) and work on it from there.
    -Rich
    *(I'm doing this because I've been on the site for almost 3 years, and feel I ought to contribute something for my time here. since I'm broke/in the hole by giant sums of money, I figgure labor ought to help more then just sitting and watching idly. )
  12. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Looks good! How about a picture gallery of trucks with varying amount of lifts and tire sizes? Like a gallery of 4" lifts with 33s, 35s, 36s, 38s, etc, then one with 6" lift and 33s, 35s, 36s, etc. Just do total lifts to account for body lift and suspension lifts in one, and use one side profile shot and one shot from head-on. Make all of the pics the same size, organized very neatly with a very simple caption listing the lift size, tire size, wheel size and backspace, and any other things that might be relevant, such as offset 0 rates. I could probably work on gathering pics if you want, I'd just make apost and ask people to send me the relevant info.</font>
