farwell to another big block, and pics of a blown 350
Discussion in 'The Garage' started by supersize75, Jan 27, 2004.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    The 454 is out and a nasty, dirty 350 is in, funny though because I just found another 454 block. I guess I just put in a 350 so I can pic up the new 454 block on friday with the blazer /forums/images/graemlins/doah.gif 1 day motor swaps are too fun for words to describe /forums/images/graemlins/1zhelp.gif
    here is the 350 I blew a couple of months ago... going down the free way and BOOM, an hour later a tow truck arived and I had the motor ready to swap out already /forums/images/graemlins/thumb.gif
    Maby after I get the new big block in I'll get at least a few months before another motor swap /forums/images/graemlins/rolleyes.gif
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Something tells me that you do entirely too many motor swaps. /forums/images/graemlins/thinking.gif Thats a lovely vented oil pan you have there. Did you pick up that hi-po mod from a ricer? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Better luck with your next motor endevour!
    Kris
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I bet not having inner fenders helped. /forums/images/graemlins/grin.gif
  4. supersize75
    Sep 27, 2002
    2,638
    For the next motor...
    I'll start the betting at... 4 months befor it goes /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/frown.gif
  5. supersize75
    Sep 27, 2002
    2,638
    you bet /forums/images/graemlins/thumb.gif I can take out my motor mount bolts while standing and with the headers on still /forums/images/graemlins/deal.gif
    body lift also helped with the 6 tranny bolts /forums/images/graemlins/grin.gif
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    And I get fun of for my yearly motor swaps. /forums/images/graemlins/rotfl.gif I think I could do motor swaps in about 3 hours if I didn't have to deal with AC.
  7. supersize75
    Sep 27, 2002
    2,638
    my ac is nice, I get up to about 50 and she blows real good /forums/images/graemlins/thumb.gif
    I actually spent almoast 600 to 700 bucks during the resto for all new ac parts...then decided I didn't want the top or doors to ever be on, so I just made a plate for the firewall /forums/images/graemlins/tongue.gif
    I'll just have new ac for the next 73-75 I get /forums/images/graemlins/thumb.gif
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    So.. for the record... how many motors have you pulled out and put in the Blazer. (as of now) We all know the number could double in a month or so. /forums/images/graemlins/rotfl.gif
  9. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Technical Information ·HP: 720 @ 6250 RPM ·Torque: 685 Ft. Lbs. @ 4500 RPM ·Compression Ratio: 12:1 ·Bore: 4.560” ·Stroke: 4.375” ·Block: Bowtie Tall Deck with One-piece rear seal ·Crankshaft: Forged 4340 Steel ·Connecting Rods: Forged 4340 Steel, H-Beam style, Shot peened ·Pistons: Forged aluminum with full floating wrist pin ·Piston Rings: Plasma-moly rings ·Camshaft: Mechanical roller (.714” / .714” lift) (266 / 274 duration @ .050”) ·Lifters: Mechanical Roller tappet ·Cylinder Heads: Aluminum Rectangular Port with a 118cc combustion chamber ·Intake Valves: 2.25” Stainless Steel ·Exhaust Valves: 1.88” Stainless Steel ·Valve Springs: Dual spring (1.567” diameter) ·Spring Retainers: Hardened chromemoly steel ·Rocker Arms: Aluminum Roller Rockers, 1.7:1 ratio ·Push Rods: High Performance (1-piece) ·Windage Tray: All new Screened and Louvered design
    Quit screwin around and put one of these in. It even comes with a warranty. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. supersize75
    Sep 27, 2002
    2,638
    so far...
    pulled out original 350, 71,000 original miles, ran great /forums/images/graemlins/doah.gif
    then swaped in 396 /forums/images/graemlins/peace.gif
    then swaped in a 350 I got from another member, also this really helped me out because the 396 was to crazy too pass emmissions and I was not up for a cam swap. He even was cool enough to spend time on it and set the timming and made me a good deal on it /forums/images/graemlins/thumb.gif
    then swaped in the 454 after I blew the 350 while going down the free way to finally get rid of the 396 /forums/images/graemlins/crazy.gif
    then the 454 started loosing its grunt and sticky lifters, so I swap in a cheap 454 I got out of the paper, motor had a rod knock so I pulled it. "atleast I got some heads and new accessories with it" /forums/images/graemlins/tongue.gif
    So I get my 454 back from storage then I replace some internals, ad a new intake,105 amp alternator, water pump, ps pump, starter, freezplugs and a flywheel, rebuild the MSD distibutor, holly truck avenger and all new gaskets..then motors goes boom
    sooo then yesterday I pull the 454 "again" and swap in a 350 I got from a friend who owed me some bling-bling and today I will go test her out after slapping some cheap headers on.
    then friday of this week I am going to go pick up another 454 block, have it checked and then get out a mail order catolog and go postal /forums/images/graemlins/peace.gif
    well thats the plan, or I could just get the for mention motor and call it a day /forums/images/graemlins/thinking.gif /forums/images/graemlins/rolleyes.gif
    Motor swaps would be fun if it wasn't for all the little exspense's that add up /forums/images/graemlins/frown.gif
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Except for no one can find 572s for sale and that version is an alcohol motor /forums/images/graemlins/wink.gif
  12. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Hey, remember to take your daily chill pill and do this. First of all, fire your engine builder. If it's you, fire youself. Second, keep your foot off the skinny pedal as much. The way you are building your rig, I would assume you might consider it a "Rockcrawler" or "Trail Rig". If you want something to go drive like a fool, then go buy a new FROD Mustang or something.
    I mean, listen to your posts above. It sounds idiotic. "I Blow Motors". It's not making you popular. Take that chill pill.
    Im just nice enough to point out Captain Obvious here. I guess others just ignore this stuff. But, Im starting to feel sorry for your Parents here Man.
    Lay off the "Bwaaadammm Bwaaadammm" of the throttle. You DONT NEED A BIG BLOCK. They ARENT COOL in a rockcrawler. Put a tried and true TBI smallblock in and be Done. Lay off the THROTTLE and take that CHILL PILL. /forums/images/graemlins/rotfl.gif I'm laughing, so laugh with me.
    Hang around me and I'll get you whipped into a Riteous Dude. /forums/images/graemlins/bow.gif
  13. supersize75
    Sep 27, 2002
    2,638
    I was just joking about the 4 months, I am reqally trying to back off the gas.
    The parents don't really care as long as it is not thier money I am wasting, I pay my way and they get to laugh when I goof up /forums/images/graemlins/thumb.gif I will just enjoy this for now while I am young, this whole killing my truck thing is why I want another full top so bad, I am trying to find one that I can make nice "and keep it that way"
    chill pill was taken about two weeks ago, thae way I see it is this is my bad habbit, some people drink, some do crack..but I choose my chevy everytime /forums/images/graemlins/peace.gif
    I have thought about a crate 350 too, but that is an option after I have another full top, for now I want displacement /forums/images/graemlins/deal.gif
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
  15. supersize75
    Sep 27, 2002
    2,638
    ahhh I could throgh in 30 more used motors for that much /forums/images/graemlins/eek.gif
    but you get what you pay for, and for that much I would just build another k5 /forums/images/graemlins/thumb.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Yeah and you could build a better motor for less, though can't get the warranty thing going. Surprised they finally have them.
  17. supersize75
    Sep 27, 2002
    2,638
    this is when I drove the parents crazy..whn I took up the garage. I did pay for my dads cars to be in storage though for over 2 years so he never got to bent about it /forums/images/graemlins/thumb.gif
    his nexxt project is his 68 Camaro..should be fun to work on a car for once /forums/images/graemlins/rolleyes.gif
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Got enough motors sitting around for him!
  19. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I know of a sweet mid to late '80's (Full convertable is done) k-5 that for sell. Go behind Desert Rat (Rual and I-60{SE corner}).... I think his name is Chuck (cann't remember) It's a real eye cather of a truck....
  20. supersize75
    Sep 27, 2002
    2,638
    I am looking for 2000 or less, unless I find some amazing deal. I already plan on all new fenders, motor, axels ect.. so I want a cheaper one /forums/images/graemlins/tongue.gif
    oh and I just got done pulling the 350 out that I just installed, skrew that /forums/images/graemlins/mad.gif
    thing is NASTY pulled valve covers and wanted to cry, I dont trust it for a minute. Soooo tonight I am going to go look at another 454, or give up and get a 350 crate /forums/images/graemlins/thinking.gif
    or what about autozone... /forums/images/graemlins/rolleyes.gif
