Fast Idle Problem
Discussion in 'The Garage' started by rusty79beast, Jan 20, 2004.
  1. rusty79beast
    rusty79beast Registered Member
    Sep 30, 2002
    64
    Houghton, MI
    Today everything was running fine, when all of a sudden I put it in park, and it is idling probably around 2000-2500 rpm. It is a 86 carbed 305 blazer. It is really cold up here, around 0 degrees, not sure if that matters. Throttle is not stuck, any suggestions??
    Thanks,
    Paul /forums/images/graemlins/confused.gif
    Oh yeah, engine was warm, and choke was working properly...
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Does your carb have a choke on it? Was the engine already hot? It could be the choke or you might have to adjust your carb due to the temp change??
  3. dyeager535
    26,979
    Choke *was* working properly, or IS working properly?
    Those electric chokes can and do fail, you checked when it was at high idle that the choke blade was fully open?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    choke not kicking down,
    you will need carb cleanr in can, and also some kind of thin lubricant oil
    with carb cleaner clean the **** out of the linkage parts on pass side of carb for the choke step and stuff, let that dry, and then spray really think good oil of some kind on all of that, then hold throttle open by hand and keep it there and with left hand move the choke lever deal up and down throughout its travel to make sure it moves free and if engie si cold then that it springs back up and shuts choke, but not super tight
    now fire her up cold and adjust your fast idle(not idles speed screw on driver side of carb!) around 1000rpm or wher eit sounds right for warming up when cold cold
    all done
  5. rusty79beast
    Sep 30, 2002
    64
    Houghton, MI
    When the engine was warm, the choke blade was in the fully opened position like it should be, hope that helps you guys
  6. dyeager535
    26,979
    Probably sticky linkage then. Like R72K5 said.
