Fast Idle
Discussion in '1983-2005 S-Series models' started by painterbccc, Dec 30, 2005.
  1. painterbccc
    painterbccc Registered Member
    Nov 12, 2005
    47
    Tennessee
    I need a little help on a S-10 with 2.8 TBI motor. What I got is a 1990 S-10 that was a 4 cyl from factory.It caught fire then they put a 2.8 TBI motor in it. Then they pulled motor out. My son bought it and we put a 2.8 TBI motor in it. Got it running.What I need help with is the fast idle. Don't these things have a cold start sensor or something? It starts good cold, but when it warms up you have to pull the wires off of the throttle body so it will quit getting fuel, then it will start. This is just a woods truck. All I really want to do is get it where it will idle. And start back after it is warm. If there is a way to make it idle I'll put a swich in it so you can turn fuel off tot start this thing back. Like I said its a woods truck. It doesn't have to be perfect.
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Do you have any idea what ECM is being used? If the 4 cylinder ECM is in there, that could be screwing things up. I would start first with putting a scan tool on it. Information from a scan tool will tell you many things, but I would first look at the temperature sender for the ECM (if it were to read cold all of the time, idle would be high, and fuel mixture would be real rich). Make sure it is connected, and remember that there are two- one for the guage/light on the dash, and another for the ECM. Do you have any kind of service manual for the S10?
  3. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    BTW, what part on TN?
